Can't interact with "adjust last operation" menu
Open, Needs Information from UserPublic
Operating system: Arch Linux
Graphics card: GTX 650
Broken: version: 2.80 (sub 75), branch: makepkg, commit date: 2019-07-29 14:47, hash: f6cb5f54494e, type: Release
(tried also with official Linux binary)
Worked: 2.79b
Hovering over the menu items shows the correct tooltips but clicking does nothing at all. If I'm in box selection mode, dragging an item (like the size of the "add cube" operation) shows the selection box. The result is the same for both the menu in the bottom left corner and the one that appears when I press F9 or when I open it from the Edit menu.
I tried disabling OpenGL depth picking but it didn't help.
Just open a new file and add a UV sphere or something. Doesn't matter, just use an operation that can be adjusted.
Full system info:
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Not quite sure I understand correctly: Do you mean you are entering the number field instead of being able to drag? What is the selection box? (maybe a screenshot could help?)
Also:
  • Does this happen with Factory Defaults?
  • Are you GPU drivers up-to-date?
