idk is a bug or not, check this pls and help me if you can
Open, Needs Information from UserPublic
Operating system: win 7(i am the pirat)
Graphics card: invidia geforce 610m
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
first thing. I just want to paint as usual with a pen or something else, but then he starts to paint with such a grey color that I did not expect to draw such an "ring" picture. I understand that I could press some buttons which I didn’t even understand which buttons I pressed in particular. and of course I want to draw me the same way as in the second picture, which is below the number two.
tell me what kind of settings or buttons I need to click to return the previous state of the stroke color grey =(
Have you same problem with Blender 2.80 Stable release? You can download Blender 2.80 Stable from here
Your Blender 2.80Beta is a bit outdated, just to tell you, Blender 2.80 Stable was released at end of July 2019 and you still use a version November 2018 Beta
The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this issue
Check if the hardware and operating system have the latest update installed and if they are working properly outside of Blender
Next time you want report a bug you can use Help > Report a Bug item and strictly compile following proposed form, all text from [ to ] must be edited. Clearly describe steps to reproduce issue and attach a simplest possible .blend file as request.
Before you made a new bug report you must use Search box (upper right) to check if bug/issue is already reported from others users. Duplicating bugreport is a waste of time and resources for developers
Thank You
Christopher Anderssarian (Christopher_Anderssarian) triaged this task as Needs Information from User priority.
@dark999 (dark999) That's the default form :-P
@Ukio Epifan (JonyShark359666)
You can find the fill settings here:
I've amended your .blend with it...
Was that your issue?
