UI snapping popup window doesn't properly resize when the header is in the bottom
Operating system: All (reproduced in Mac and Linux)
Broken: git master
When the header is in the bottom the Snapping popup window resizes when it needs more space but it doesn't resize back when it has too much space.
https://i.gyazo.com/55ef38c43a0a7a8e0c4c1caa500a2a4c.mp4
Reported by Jellbelle in devtalk:
https://devtalk.blender.org/t/blender-ui-paper-cuts/2596/3151
Luis de Bethencourt Guimera (luisbg) lowered the priority of this task from Needs Triage by Developer to Confirmed, Low.Aug 15 2019, 3:59 AM
i cannot confirm this problem on linux Blender 2.80-4074ab361e13 AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 430.40, for me work fine
Please, update this report following strictly this template
Next time you want report a bug you can use Help > Report a Bug item and strictly compile following proposed template, all text from [ to ] must be edited. Clearly describe steps to reproduce issue and attach a simplest possible .blend file as request.
Before you made a new bug report you must use Search box (upper right) to check if bug/issue is already reported from others users. Duplicating bugreport is a waste of time and resources for developers
This is an inherent problem with popovers spawning from the bottom, and one of the reasons why headers are on the top now.
