Eevee: Modulo node behaves unexpectedly/inconsistently #68687
6 Participants
Reference: blender/blender#68687
Windows 10 Professional (x64) Version 1903 (build 18362.267)
Graphics: Intel(R) HD Graphics 630
v2.80.75
Here is an attached blend file that illustrates the issue (visible in render preview as you switch between eevee and cycles).
If you compare the outcome of mod(2x, x) between eevee and cycles. Cycles seems to correctly evaluate that to 0 while eevee seems to evaluate that incorrectly to 1 for many values of x (for both integers and fractions).EeveeModError1.blend
The bug also occurs for mod(yx,x) for many values of y (I've tested it for a couple of integer values of y).
Added subscriber: @dohduhdah
Added subscriber: @brecht
Please verify if this is still an issue in the latest build, I believe there was a fix related to this:
https://builder.blender.org/download/
Yes, I've tried it today with the latest build. There have been a few fixes, but there still appear to be problems with the modulo function in eevee.
I notice them in a more complicated setup when comparing the results between eevee and cycles:
https://blenderartists.org/t/confusion-about-color-difference-between-eevee-and-cycles/1173638
I use the modulo function in the shader nodes to generate color combinations:
https://i.imgur.com/BBqAsgv.png
Switching between cycles and eevee in rendered preview causes certain elements to take on completely different colors (while most of the colors remain equal).mod-grid2.blend
Added subscriber: @GpuDevil
This is likely a floating point precision issue regarding GLSL's implementation of
mod()
and GPU code generation, see this thread: https://www.raspberrypi.org/forums/viewtopic.php?t=189455Seems like the issue with mod(x,x) != 0 isa regression. However, the imprecision pointed by @GpuDevil is likely to remain as it is an implementation behavior we cannot ensure. And I tried expanding the terms and it did nothing.
This issue was referenced by
d9be59e872
Added subscriber: @IyadAhmed
I still see the problem in 2.82, it occurs whenever there are negative numbers as input for both Vector Math and Math nodes modulo, EEVEE seems to be more accurate, it is the Cycles implementation that doesn't produce desirable results.
@IyadAhmed, it's best to create a new report then with example .blend file and system information, to be sure we are looking at the same problem.
Indeed it is not exactly the same problem, however the problem above still exists in 2.82 and blender-2.83-1a1f2912e65e-windows64, screenshots using the above file "EeveeModError1.blend"
