Missing Gizmo information in the API documentation
Confirmed, NormalPublicTO DO
Copy from devtalk : https://devtalk.blender.org/t/gizmo-api-documentation-missing-infos/8965
Hi, here is a list of what I found was missing by Gizmo type when looking in the code.
  • List of the name of GizmoType : GIZMO_GT_* we can use, like for the icons.
  • GIZMO_GT_arrow_2d
    length : arrow length
    angle : do nothing
  • GIZMO_GT_arrow_3d
    draw_options : {'STEM'} do nothing
    draw_style : ('NORMAL', 'CROSS', 'BOX', 'CONE')
    transform : {'INVERT', 'CONSTRAIN'} 'CONSTRAIN' crash Blender
    aspect : (flt, flt) do nothing
  • GIZMO_GT_blank_3d
  • GIZMO_GT_cage_2d
    draw_style : ('BOX', 'CIRCLE') Box = Open cage / Nothing = Closed Cage / Circle = Do nothing
    draw_options : ('XFORM_CENTER_HANDLE') do nothing : Not working, should work with 'BOX' draw_style for open or closed cage.
  • GIZMO_GT_cage_3d
    draw_style : ('BOX', 'CIRCLE') Box = 3D cage 1 handle / Nothing = 3D Cage multiple handles / Circle = Do nothing
  • GIZMO_GT_dial_3d
    draw_options : ('CLIP', 'FILL', 'FILL_SELECT', 'ANGLE_MIRROR', 'ANGLE_START_Y', 'ANGLE_VALUE')
    wrap_angle : Bool True : add offset value indefinitely // False : Only add offset for one turn
    arc_inner_factor : 0.5 Add inner circle in middle // 1 = size of outer circle
    arc_partial_angle : Show Partial Dial
    incremental_angle : flt Angle to snap in steps
    click_value : Value to use for a single click action
  • GIZMO_GT_button_2d
    draw_options : {'OUTLINE', 'BACKDROP', 'HELPLINE'}
  • GIZMO_GT_move_3d
    draw_style : ('RING_2D', 'CROSS_2D')
    draw_options : {'FILL', 'FILL_SELECT', 'ALIGN_VIEW'}
    use_snap : Bool
  • GIZMO_GT_primitive_3d
    draw_style = "PLANE" only plane
  • GIZMO_GT_value_2d ??
Thanks a lot for your work.
Aaron Carlisle (Blendify) lowered the priority of this task from 90 to 50.
Aaron Carlisle (Blendify) moved this task from Backlog to Python API on the Documentation board.
Aaron Carlisle (Blendify) changed the subtype of this task from "Report" to "To Do".
