Math with Nodes #68734
16 Participants
Reference: blender/blender#68734
Currently, there are two main math nodes: "[Float] Math" and "Vector Math". The current workflow for using these is that first the correct math node has to be inserted, and then the correct operation has to be selected. This approach has two problems:
A more scalable approach is to remove the "Math" node entirely and create individual nodes for different operations. For example, there will be an "Add", a "Subtract" and a "Dot Product" node. These new nodes can adapt to the data types that are connected to them.
This is not a change we have to do in the short term, but in the long run it is the better solution in my opinion. Especially as we get more types and operations.
Added subscriber: @EitanSomething
I generally like this idea, but it would take more time to switch between math operations
That is true. However, I'd argue that it is worth it. I expect that you have to switch the operation relatively rarely.
Maybe a drop down menu by the name of the node would give options of the other nodes in the nodes path.
Example :You would be able to see everything inside of math section.
Added subscriber: @Poulpator
It's not possible to create shortcut to math node e.g insert "Multiply" add a math node with multiply operation ?
Of course that is possible, I'm doing that for years already in Animation Nodes. But it does not solve the entire problem.
Added subscriber: @Momotron
I agree Math sounds more like a general term and could be used for more complex nodes like decimal/exponential
Added subscriber: @3di
This could cause more problems than it solves.
Often people select the wrong type of function through lack of knowledge, then realise it when the results aren't as expected. Not much of a problem at the moment because you can change it easily from the existing node's dropdown. If you have to replace the entire node then it's a lot of steps to delete the node, add another node, and then hook things back up properly, if you get the math wrong a number of times this could become frustrating. Also the menus system would become bloated (although sub menus would help as Eitan suggested above).
I guess a solution that would fit all would be to have a sub menu off of the math listing, and then use whatever's selected to set the operation type in the math node's dropdown. That way it can be easily changed if necessary , and allow users to add with one click.
Added subscriber: @Rusculleda
I know things should work fine by default, but node wrangler is an very commonly used shipped addon that maybe should be enabled by default, and it solves the problem you are pointing out (shift+s)
Added subscriber: @EAW
Added subscriber: @MauroPfister
Added subscriber: @lemenicier_julien
Added subscriber: @BartekMoniewski
Added subscriber: @hadrien
If there's a single multiply node that can handle floats and vectors, how does it interface ? We should keep the value field when nothing's connected to the socket, but how should it behave then ? as a vector, or a single value field ?
Added subscriber: @HDMaster84
I do switch between math nodes all the time. It is like the blend modes for a color mix node. It does definitly make sense to put it in a single node. I really like how the current math node in cycles material nodes works right now. From a technical point of view it might not make sense but from an artistic point of view where experimentation is a common thing it does make sense.
We could add shortcuts to the most common math operations though (like multiply, add, substract, divide and power)
Added subscriber: @CharlieJolly
I touched on some design aspects in #73512 when looking to add a Vector Map Range to Cycles.
Added subscriber: @RedMser
Added subscriber: @Aeraglyx
Added subscriber: @1D_Inc
Yes, changing math node mode is like changing layers blending modes, like in photoshop or krita - with the ability to check the result immediately.
