selecting an object in the outliner doesn't update the properties panel, only selecting in the 3d viewport updates the properties panel.
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
Broken: version: 2.81 (sub 2), branch: master, commit date: 2019-08-16 18:51, hash: rBe8ffe25eb111
select an object in the outliner, properties doens't update.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Oct 30 2019, 2:38 PM
I cannot reproduce this with either the latest stable or current development versions of Blender:
Please try the latest daily build: https://builder.blender.org/download/
Go to File โ†’ Defaults โ†’ Load Factory Settings and then load your file to see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
michael campbell (3di) added a comment.EditedOct 30 2019, 3:08 PM
just installed todays 2.81 build and reset to factory defaults. Same problem.
Additionally I've noticed that if I try the same on a 1080p monitor it selects even less. My video is on a 4k monitor.
Thx for getting back.
Is this about updating the properties editor (as the report tiltle suggests)?
Or about viewport selection failing for small objects? (I can repro that, but that would be a duplicate of T63356: Small object are not selected with Box Select tool...)
I've just tested a bit more and found that the problem is only with box select. lassoo and circle select work properly it seems.
ah crap, sorry I didn't read the title properly and thought I was replying to a different bug I raised :D Yes close this one, the properties section is updating correctly now.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Oct 30 2019, 3:24 PM
OKi, closing...
