Particle Edit Mode Hair vertex doesn't follow vertex theme color ( non selected and selected )
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.81 (sub 2), branch: master, commit date: 2019-08-16 18:51, hash: rBe8ffe25eb111
Changing vertex theme color on particle edit mode Hair will not reflect on 3D Viewport. It relfects on mesh edit mode though.
I also tried on 2.80 official build same problem. But It's fine in 2.79.
01. Give default Cube hair particle system
02. Change the mode to Particle Edit mode
03. Press 2 to switch to Point
04. Open Preferences / Theme / 3D View. Find Vertex and change the color will not changing the point color
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Aug 19 2019, 3:14 PM
Can confirm, havent checked code but selected seems to (falsely) follow Edge Select theme color...
Philipp Oeser (lichtwerk) triaged this task as Low priority.Fri, Jan 31, 1:05 PM
Not sure anymore if we should keep this open.
  • Atm., it uses the TH_EDGE_SELECT / colorVertexSelect (as stated in the previous comment), true.
  • Atm. it interpolates the strand in the shader (two shaders here: strand and point, both use TH_EDGE_SELECT, doesnt make a distinction between the hair key and the segments inbetween)
  • I am not sure if it makes sense to have a distinction here (to me, a separate color for keys and segments would not make a lot of sense, you are only ever interacting with keys, not segments -- selection, grooming, etc.)
  • If we stick with one color, which one is better? TH_EDGE_SELECT (because hair is such a long "edge") or TH_VERTEX_SELECT (because you are mainly interacting with hair keys / verts)?
Personally, I would go with TH_VERTEX_SELECT, like 2.79 did.
Sidenote:
  • CacheEditrPathsIterData and PTCacheEdit have sel_col and nosel_col, to me it looks like these are not used and could go?
CC @Clément Foucault (fclem) , @William Reynish (billreynish)
