GPencil: Include Material as new filter in modifiers
Closed, ResolvedPublicPATCH
Actually the modifiers can be filtered by index pass, but not by material.
Actually, when you filter by layer you can set the filter using the name, but for materials you must use an index. The index is great if you want use several materials at the same time, but for one material only is not intuitive.
