Improve UV packing to pack more tightly (not just considering bounding boxes)
Confirmed, NormalPublicTO DO
None
Dalai Felinto (dfelinto)
Aug 20 2019, 7:58 PM
Tokens
"Love" token, awarded by mindinsomnia."Love" token, awarded by DiogoX2."Like" token, awarded by knightknight."Love" token, awarded by nosslak."Love" token, awarded by SimonH."Burninate" token, awarded by koloved."Love" token, awarded by dbystedt."Love" token, awarded by rbx775."Love" token, awarded by penguinburger1."Love" token, awarded by xdanic."Like" token, awarded by eobet."Love" token, awarded by 0o00o0oo."Like" token, awarded by Fracture128."Love" token, awarded by Valerush."Love" token, awarded by AndreasAustPMX."Love" token, awarded by Caetano."Love" token, awarded by Mephisto."Like" token, awarded by andruxa696."Love" token, awarded by brilliant_ape."Love" token, awarded by iWaraxe."Love" token, awarded by juantxo."Love" token, awarded by franMarz."100" token, awarded by Frozen_Death_Knight."Love" token, awarded by n-pigeon."Love" token, awarded by kookitoo."Love" token, awarded by maxivz."Love" token, awarded by Shimoon."Love" token, awarded by LukasStratmann."Love" token, awarded by Draise."Love" token, awarded by Zuorion."Love" token, awarded by michaelknubben."Love" token, awarded by fiendish55."Love" token, awarded by monio.
Better UV island packing algorithm that does not only consider bounding boxes of islands and packs more tightly (even if slower)
Dalai Felinto (dfelinto) lowered the priority of this task from 90 to Normal.Aug 20 2019, 7:58 PM
Dalai Felinto (dfelinto) created this task.
Dalai Felinto (dfelinto) edited a custom field.
In terms of UV packing and UV unwrapping, it's common in other software to have a progressive heuristic solver. Something that you let run for a couple of seconds until you're satisfied with the result.
Is there a task for to improve the UV editor itself? Right now it still has remnamts of the image editor and it could be improved. I made a couple of proposals about it here and here
Campbell Barton (campbellbarton) renamed this task from UV Mapping Improvements to Improve UV packing to pack more tightly (not just considering bounding boxes).Nov 27 2019, 4:19 AM
Campbell Barton (campbellbarton) triaged this task as 30 priority.
Campbell Barton (campbellbarton) updated the task description. (Show Details)
Do you mean Packmaster / Shotpacker addons?
Aaron Carlisle (Blendify) changed the task status from Needs Information from User to Confirmed.Feb 18 2020, 12:17 AM
Also, please, remember, that current packing behavior is good because it is fast, that is suitable for the most cases and especially nice for heavy meshes.
If to completely replace it with heuristics instead of adding it, it is possible to get the same problem as with the undo - low perfomance for every use case instead of when it's really needed.
