We want to make subdivision surfaces a property of the Mesh datablock. The modifier would remain, but would likely be used less.
There are a few reasons for this:
- OpenSubdiv GPU acceleration in the viewport and adaptive subdivision in Cycles need the modifier to be last in the stack. The available settings, behavior and implementation would be more clear if this was controlled outside of the modifier stack.
- When we add modifier nodes support, the concept of a last modifier in the stack becomes fuzzy. Being able to pass along a subdivision surface Mesh to another node without actually subdividing is important for performance and to leave subdivision to the renderer.
- For best performance with GPU acceleration, we don't want Blender to also subdivide the mesh on the CPU at all. But operations like hair positioning, particle emission and snapping still need to take into account the subdivision surface. If the Mesh datablock contains all the subdivision surface information, these could potentially work on the limit surface without subdividing the mesh on the CPU.
- Simpler smooth normals handling, see T68893: Smooth shading usabilty.
- File formats like USD have native subdivision surface primitives. By making it part of the mesh, we are more compatible with such file formats.
