Related Objects
- Mentioned In
- T85806: Erro na sombra
T83524: Cycles smooth shading bug
T78497: Bevel shader doesn't work properly
T77992: Cycles - doesn't render cone correctly
T77375: The shadow line is jagged in Cycles
T74891: smooth shading not working with noise bump
T73767: ambient occlusion and shade smooth
T73082: Terminator Problem continues in 2.82 beta and 2.83 alpha
T70716: smooth shading doesn't appear work at all in both cycles and EEVEE
T37814: Artifacts in Cycles render for lowpoly models.
P1075 New Tasks for the Modules
T66305: Render & Cycles Module - Mentioned Here
- D7634: Cycles: Added shadow terminator offset parameter.
D2574: Cycles: Implement optional normal adjustment that ensures valid reflections for normal maps and bump maps
D5399: Cycles: Add bump-map shadow terminator softening term
To address this issue, what do you think about adding a "shadow bias" parameter to control an offset from the surface along the geometric normal ? I know its not a perfect solution but at least it would allow users to avoid a lot of rendering artifacts that are due to shadow termination.
If you're ok with that I can try an implementation.
I'd prefer us to first try a better solution, like ignoring backfaces, which may not be all that complicated.
Also as described in T37814#773025, this needs changes in BSDF evaluation too.
From what I understand of this "problem", this visual artifact is mainly due to low poly meshes having smooth shading enabled: you cannot fix the fact that a triangle is completely hidden from a light (from a point/directional light the artifact is obvious, it becomes less visible for large area lights). So for me it is basically just an incompatibility between the resolution of the mesh and its shading that try to simulate a smooth surface. Therefore I don't understand how ignoring backfaces could help, could you explain your idea ?
I never tried to dig deeper into that problem so I may miss something. Maybe some mathematical solution based on a reconstruction of the approximated continuous surface exists, but it seems complicated. In our previous renderer we "fixed" it with the simple shadow bias strategy that I mentioned, so that it can handle production. When the problem occured, our artists just increased the value and re-render the specific shot. However the problem was mitigated by the fact that artists used a subdivision level high enough on important assets, and almost only area lights.
That's why I am proposing the shadow "bias solution" here, but I can understand that it is not enough and cannot be considered robust. However with a default value of 0 I think it cannot hurt to offer that kind of control to the user, what do you think ?
I've just spoken to Jules Urbach from Octane, he's going to ask Lino from his Dev team to help you out.
@Laurent Noel (c2ba), I think someone should try an automatic solution before we add manual settings.
The issue happens when a reflection ray goes into the mesh, and then wrong shadow comes from when it exits. So if we ignore that exit, it may solve the most common type of problem. It's even possible to experiment with this using just a shader setup with a transparent BSDF on the backside, to see how well it works. Either way, any solution will need changes to the BSDF evaluation first.
Is this what you meant Brecht? Doesn't seem to make any difference if so. Also makes no difference if shadows are disabled on the light, and if glossy rays are turned off for the light.
This seems to be the most used solution I can find:
and this one from siggraph this year, which I thought had already been implemented? Doesn't seem to be working if so.
Read the SIGGRAPH paper more closely - it applies to problems introduced by bump/normal mapped surfaces only. It is implemented and working.
Yeah the problem of shadow terminator for normal maps seems to be fixed thanks to https://developer.blender.org/D5399
- Before the fix with the scene provided by Stefan: https://cloud.blender.org/p/home/5da861858ca20a9414af8cca?t
- After the fix: https://cloud.blender.org/p/home/5da861fad2bf7c8344de5a5b?t
Cleary the shadows are smoothed enough where the artifact occurs.
However @Lukas Stockner (lukasstockner97) I was wondering why you limited it to diffuse surfaces ? the paper does not mention anything about any kind of diffuse restriction, so in the cloth scene provided by Stefan if you replace the diffuse BSDF with a glossy one the artefact pops up again. Two screenshots:
- Glossy BSDF: https://cloud.blender.org/p/home/5da862568ca20a9414af8cce?t
- Fully metallic Principled: https://cloud.blender.org/p/home/5da8630dbca937ff2e5947ff?t
So I think the fix should be generalized to any kind of scattering behavior (except maybe toon ones ?)
Now the original and "simpler" shadow terminator issue (this one https://computergraphics.stackexchange.com/questions/4986/ray-tracing-shadows-the-shadow-line-artifact) is a different problem. I don't think it can be solved without adding lighting from the backface of the triangle (in bsdf_eval function and sample probably, doing something in the else case of "if (dot(sd->Ng, omega_in) >= 0.0f) {"). That's a bit cheating but, after all, interpolated normals are a cheat. Also in my experience it is hard to do without suffering from side effects such as light leaking occuring in some cases. Maybe it should be a boolean parameter that control this behavior ?
Right now it is true that low resolution assets such as video game assets are just not acceptable when rendered with Cycles, or you have yo use large area lights to mitigate the problem :/
On the video above you can see that the shading issue is apparent even on the far right polygons where the light ray isn't passing through other faces and then hitting the back side of neighbouring faces.
I'm not really sure but I think it might be related to the linear interpolation of the vertex normals on the face, that does not match the true normals a circle would have (correct me if I'm wrong). So each face get a set of interpolated normals that is slightly wrong, and since the interpolated normal is used to build the shading normal with the tangent normal map, correlation artifacts appear.
Try the following: build a cylinder in blender, remove the top and bottom faces, then in edit mode select all faces and subdivide them multiple time. Put your cylinder in smooth shading and you will see the the individual original low res faces appear, even with opengl rendering.
I guess this is because the new vertices created with subdivision have a normal computed from linear interpolation, but I'm not familiar with subdivision algorithms in general and the one used by blender in edit mode so I can only guess. Try to display the normals on edit mode with the overlay, you will see that the normals of the newly created vertices do not create a perfect circular pattern.
You have to imagine that Cycles is using theses kind of wrong normals on each point of a face. It is ok for low frequency shading, but when you add a high frequency normal map on top of that, the error becomes visible.
In brief I think your issue cannot be solved as long as interpolated normals are obtained from linear interpolation (which is the case for all renderers I can think of), you need a mesh with higher subdivisions, where normals are correctly computed (in the case of the cylinder, a catmull clark subdiv modifier gives me perfectly circular normals).
I've tried the same mesh in redshift and also in mantra. The shading issue is not there in either. See this bug report where I posted the comparison.
https://developer.blender.org/T70716
The test you suggested of adding extra subdivisions in edit mode should result in the shading artefacts because there's more geometry between the original edges. The same way you would intentionally add a hard edge by putting two edges close together.
The issue is still there even if using a subdivision modifier, it's just less noticeable because the angle between the faces is lower, so the difference in shading per face is lesser. There is still no smoothing of the shading between neighbouring face. Here's the same mesh with a subidivion modifier added:
Here's a perfectly cylindrical mesh with perfectly cylindrical normals:
with bump map:
without bump map:
Here's the .blend if anyone wants to see if they can improve the coding to get this shading correctly. It's almost as if the bump/normal maps are using the face normal instead of the merged vertex normals for overall shading?
Ok after another test I'm convinced: while subdividing in edit mode Blender does not seem to interpolate the normal at all (all new vertex has its normal being the same as the face it was created on), so the test does not show anything sorry ^^'
I'm gonna try with Arnold tomorrow at work to see how it behaves for that scene.
I still think it might have to do with the linear interpolation of normals but again, not sure at all, some experiments in the code are required (found this old paper https://webhome.cs.uvic.ca/~blob/publications/p397-van_overveld.pdf addressing the fact that linear interpolation of normals is not a good approximation, but no mention about the interaction with normal maps).
Also the artifact is far less visible with Eevee:
Cycles:
Eevee:
For subdivision modifier, putting it to 3 seems to be enough to completely get rid of it:
subdiv 1:
subdiv 2:
subdiv 3:
subdiv 4:
It seems strongly influenced by the normal adjustment that was introduced in: https://developer.blender.org/D2574
For example by removing the line https://developer.blender.org/differential/changeset/?ref=147520 I get the following image:
For comparison, I have this without remove the line:
Some triangles are still slightly visible on the right of the mesh, but nothing like the original.
Also it strikes me how different is the overhaul look of the mesh when the normal is not corrected according to D2574. It's like the illumination is completely different Oo
Is there any way to vote to get this escalated to high priority? I literally can't use cycles at all in scenes with curved surfaces that have bump/normal maps......which is most scenes.
This seems to fix it. Left is a bump map, middle is a normal map, right is a normal texture run through an alternative node setup instead of the normal map node. The bump is controlled by map range nodes instead of the normal map's strength parameter.
the normal pass:
The file:
Slightly better version:
Same again, left is the bump map node, middle is the normal map node, right is my custom node setup, but this time mixing the object smooth normals back in.
Normal pass:
file:
For what it's worth, a little insight in what other renderers do (in the case without bump maps)
LuxRender: Nothing.
"the black triangles on the edge are unavoidable, their geometric normal points away from the light source so there is no way to fix them aside increasing tessellation and/or using softer shadows (due to a larger light source, etc.)"
https://forums.luxcorerender.org/viewtopic.php?f=5&t=1286
RedShift: Shadow ray bias derived from triangle size and the deviation between geometric and shading normal
https://docs.redshift3d.com/display/RSDOCS/Shadow+Ray+Biasing
For this one to work, some change is required in bsdf evaluation because right now the contribution is completely black when dot(Ng, omega_in) < 0.
I don't think there's any way around this without ignoring backfacing geometric normals.
@Stefan Werner (swerner) Here's another piece of test geometry. This time the parts of the model with the artefacts aren't that low poly, also there's no normal map applied. Not sure if it's actually a bit worse than in previous builds? Currently I'm using 2.82 (sub 1), branch: master, commit date: 2019-11-22 18:14, hash: rB373e936e3e64
I was made aware that Appleseed has introduced a workaround for the shadow terminator. Their method, just like the fix for the bump map issue, is pushing the shadow terminator towards the light source, that is darkening the surface overall.
A quick and dirty attempt at implementing it in Cycles:
https://github.com/skwerner/blender/commit/5de4c6371d8f772e04e6c0383dfd8f1be6a29bd1
@Stefan Werner (swerner) , awesome! To get this, do I have to download blender from github and build myself, or is this in todays daily build from the main website? Never build it before.
You'd have to build your own, and I consider this patch nothing more than a proof of concept. In my limited testing, it appeared to break CUDA rendering and I haven't tested it BRDFs other than diffuse and principled surface.
I quickly tried your fix on a sphere. The parameter is animated from 0 to 1 over 100 frames. It seems to work well but need to be fine tuned to get rid of artifacts while not loosing too much lighting. I also get funny results starting from shadow_terminator_offset = 0.67 approximately :p
Hi, Franz from appleseed here.
Awesome :)
Indeed, the theorethical maximum limit before "ringing" appears is exactly 2/3 (0.666...).
I noticed that as the offset is increased, the edge of the shadow becomes harder, would this need to be compensated for in the code?
Hi devs,
it would be great to keep an eye on this to find a solution. Arnold and Redshift have fixed the ray-tracing feature successfully.
The topic comes up again and again in the Blender groups on Facebook and everytime I fight hard to explain that this isn't really a bug and not ignored by the devs. People react very annoyed. Actually I could research a little workaround by offsetting the shadow to cover the Terminator effect manipulating the normals but this is more a dirty workaround for artists struggling with low-poly designs. The workaround affects also specular/reflection too extreme.
Anyways. Thanks for your overall great work.
@Michael Klein (Renderbricks) , @Stefan Werner (swerner) has fixed the problem a bit higher up using the opensource code from appleseed. I think we're just awaiting someone to authorise it's incorporation into Cycles.
On the Blender Live stream @Dalai Felinto (dfelinto) mentioned @Brecht Van Lommel (brecht) plans to look at it in the next few months.
I noticed that EEVEE too has a terminator problem, though it is less notable. Can the fix work for both?
Hi devs,
I saw a comparison of an Appleseed rendering and it's using an offset of the shadow to cover the Terminator problem. If this is still the fix then it's more a workaround but not a solution because the shadow is calculated wrong in this case.
Hi, Franz here, appleseed founder & lead dev.
Historically our strategy to alleviate shadow handling terminator artifacts was to let the user specify a per-object shadow ray offset (we called it ray bias). That was an acceptable "solution" as a last resort but by no means a general one.
The new technique that we use (I call it "frequency-shifted cosine") is far from perfect and can cause new artifacts but it's strictly superior to our previous ray bias technique. On the upside it's very cheap at runtime and trivial to implement.
There are definitely other techniques, I'm thinking of one in particular (not my invention) but it requires to add handling code in the intersection code.
I think it should? To expand somewhat on the "cosine-frequency shifting" technique I mentioned in my post just above: the idea is simply to hide the artifacts in the shadow by moving the light-to-shadow transition back (less light, more shadow).
We could like... Email someone at Arnold and Redshift and just ask for a basic rundown of how it's done. It's not like a big secret or anything. But who knows! Maybe one of them will be able to give the Blender team some pointers?
Francois, you could be like our SPY! Since Appleseed is not a direct competitor. Then you would slip the devs a yellow envelope with the info!
Just an idea.
We really should just ask.
Hi all,
I had an in depth look of this issue and my troubleshooting experience may help.
I think we have 2 issues here. They appear both in CPU and CUDA rendering, and none of them affects eevee.
This one triggers some bad face normal values for a very limited set of triangles. Not directly related to our issue, but worth noting. If I had to make an educated guess, I would bet on a boundary condition handling issue with the first/last triangle triangle's stripe.
This issue only come from direct light. Indirect lighting seems not not affected.
This one is the one described in the thread. All triangles that do not "face the light" (negative dot product with the light source position) seen to be affected. I would rather think it's a bug to solve that a feature to add. I think that cycles is using a shortcut when processing direct diffuse light, and do not apply any lighting when the face normal dot product with light source position. This is not correct, according to me you can apply this simplification by checking if dot product with all 3 vertex normal composing the triangle is negative, otherwise you have to light your triangle accordingly.
It would be nice if someone familiar with cycle direct lighting calculation in the code could check this. (I'm not)
Thanks in advance for your attention
@Michael bernardoff (kriptomik) EEVEE is using shadow mapping techniques and the Terminator Effect is a result of raytraced shadows.
@Michael bernardoff (kriptomik) if the triangle does not face the light, it means that for a closed mesh a shadow ray starting from it will intersect with another triangle. It's not a matter of changing the shading only, it's a mismatch between the smooth normal and the actual sharp geometry when tracing the shadow ray.
This paper explains it:
https://www.researchgate.net/publication/3208559_It's_really_not_a_rendering_bug_you_see
OK thanks a lot, good paper -> got it.
Found a nice solution explanation here. So hope is with us.
Thanks for your guidance !
The solution you linked is only for bump/normal mapping, for which we have similar code in Cycles. Artifacts from smooth normals on sharp geometry are something else.
Is there a non biased solution ? Intuitively, the one I mentioned in my first post should work but it would require to shoot 3 path per smooth triangle to compute lights interactions and have vertex normals available. I'm not even sure it's compatible with BVH and all the current path tracing algorithm but it should solve this discontinuity issue.
I'm not sure what the exact solution is that you are proposing. What you would do with the result of doing a dot product or tracing a shadow ray for each vertex. You might find out that the triangle is susceptible to shadow terminator artifacts, but then how do you actually generate a smooth shadow terminator?
My earlier comments in this task suggest a possible solution by ignoring certain backfaces in ray intersection. Not sure which definition of "non biased" you are thinking of, but it would be closer to the ground truth than the current shadow terminator offset.
Sorry for the lag, but Ineeded some sleep :) I'm new here, so not familliar with all vocabulary, so don't hesitate to ask for clarification if required.
Rationale for this thinking is that by considering only the face normal you are loosing some information. Normal space withint the triangle is not constant, it's a linear interpolation of triangle's verctrices normals, described by the vectrices normals. So if any these 3 vectrices normal (boundary conditions) is facing the light, part of the triangle is facing the light even if it's normal (could be considered as an averaged value) is not. I've not done the math, but it's all linear so it's a reasonnable assumption.
Appart from the first issues I mentionned (let's forget about it ATM), normals continuity seems OK (smooth shading means that normals withint the same object island are continous), so if you just cast rays at that triangle without rejecting lights interaction based on triangle normal, the shadow termination shading should compute correctly for that triangle. Support for this assumtion is that the other triangles in the shadow terminator are shaded correctly, the only difference is that their normal face the light and their interaction with lights is computed, and not rejected.
"Non biased" mean not trying to hide the problem by a shader trick :)
If it still not clear, please let me know, I'll provide visual support.
Thanks again for your attention !
The issue is that when tracing a shadow ray from any point in the triangle, another triangle will be hit and the point will be considered shadowed. This is not happening based on any normal, it's purely based on vertex positions.
That is what needs to be addressed, and I don't think your solution does.
You're right, it'll hit a triangle adjacant to our bad guy (backface only, but I don't think cycles cares). I didn't get that. This would be correct if the triangle hit is not smooth, incorrect if it is smooth.
There is probably something to do about it too if you introduce the triangle that induce the shadowing vectrices normals into consideration but it's starting to be computationnally expensive (same rationale than before, we're discarding information we should not).
I'll think about it and let you know if I can find a similar solution.
Doh ! Smooth triangles really requires special attention to get the shadows right !
Your original post was just prefect in fact :) Sorry wasting your time...
