Graph Editor: Link Visible and Selected states #68962
7 Participants
Reference: blender/blender#68962
Working with many curves in the GE currently requires animators to often toggle the visibility of curves and then select the newly visible curves.
Linking 'visible' and 'selected' would make it faster to use the GE. However, having those two always linked would remove the feature of having certain curves visible "in the background", i.e. visible but unselected. We do not want to lose this feature.
Proposal: Add a user preference to link 'visible' and 'selected'. When this mode is enabled:
We think a user preference is best for this, as we suspect it's a personal preference and not so much something you want to manage per GE editor.
Added subscribers: @dr.sybren, @Hjalti, @PabloFournier
Added subscriber: @NachoConesa
Added subscriber: @WilliamReynish
Graph editor: link Visible and Selected statesto Graph Editor: Link Visible and Selected statesAdded subscriber: @LucianoMunoz
we have something remotely similar :
the biggest problem with this, is that, even if you only have one channel selected, it still considers the rest of the "disabled" channels for the zoom so it becomes really awkard when you press "home" and because it doesnt select the keys so you need 4 extra steps every time you want to focus on a specific curve.
+1 !
What @LucianoMunoz mentions (Home taking into account disabled channels) seems like a bug and should be discussed as a separate task.
Added subscriber: @Oskar3d
Added subscriber: @lichtwerk
That is actually reported as a bug in #67873 (View Selected in Graph Editor (Only Selected Curve Keyframes) takes hidden keys into account when calculating zoom), I was planning to have a look today (after it has been sitting around for very long... shame on me...) Would this investigation be obsoleted then?
Posted patch for above annoyance bug: D6237: Graph Editor: Fix selection and View > Selected with 'View Only Selected Curve Keyframes' option enabled, maybe it is helpful already?
The 'Only Selected Curve Keyframes' feature covers most of this task, indeed. The major visible difference is that it still keeps the curve itself visible, and only hides the keyframes. I have no opinion on that, I'll leave that to @LucianoMunoz, @Hjalti, @NachoConesa
and other interested animators to discuss.
What's left is this:
Currently the 'Only Selected Curve Keyframes' setting is per graph editor. How important is it to have this setting as a user preference?
Diving into this more, I also have the following question regarding selection:
is ON: [box/circle/lasso] select will not select non-visible keyframes anymore, see D6237: Graph Editor: Fix selection and View > Selected with 'View Only Selected Curve Keyframes' option enabledOnly Selected Curve Keyframes
is ON?: [basically all under theSelect
menu]View Selected
from the selection behavior in {D6237}?Added subscriber: @JulianEisel
Subscibing @JulianEisel here as well (since he is working on D6235: UI: Changes to graph editor selection and transform -- to avoid possible overlap/conflicts...)
This comment was removed by @dr.sybren
Added subscriber: @pablovazquez
Added subscriber: @Fynn-Ribbeck
Nowadays, we kind of have this feature using these two settings:
But, I guess that having the curves' opacity at 0.001 means they are still drawn and using resources. If so, could this be fixed?
Also, to make this truly powerful, it would help a lot of click if we could select a parent channel (like the object or the action channel) to be able to see all the children channels' curves. As requested here: Display of the curve in the graph editor — Right-Click Select
And, when we select a controller in the viewport/outliner, have its graph channels (or object channel) automatically selected so to not start with an empty graph.
yep I explained that in this video 2 years ago: https://www.youtube.com/watch?v=6IwhigPZuqk
other things that would be necessary would be the channels to be uncollapsed when you select an object/bone
Well yes, because 0.001 opacity is still "technically visible". It's not zero, I mean. It doesn't go down to zero to make clear that if you want to completely hide unselected curves, this is not the option to do so.
Having said that, I think we can indeed simplify some things here. For example by visually grouping the options together. Also having 0.001 as minimum value is a bit weird, as it's less than 1/256th, so with Blender's internal 8-bit color system it's effectively hiding everything anyway. A better minimum would be 0.01.
We just unify the two settings, and have 0.00 as minimum and anything below 0.01 will act as "Only Show Selected" is set. I'm sure someone will curse at that though, as it's taking away the option to toggle between "shown with a specific opacity" & "hidden" with just a single click.
That's a nice idea. It would require quite some lookups of the FCurves' data paths to understand these relationships, so there is a performance implication that should be investigated. For this a RCS post would also be useful, so that the people who want this feature can collaborate on working out the details (like what happens when you hide a parent bone, which will deselect it; what happens to the children then?)
That RCS needs to be re-titled, as "Display of the curve in the graph editor" doesn't mean much. I mean, Blender already shows the curve in the graph editor. The images in the post are also broken. This is not something to give to a small team of developers who already have enough work to keep them busy for the next decade.
This is already a thing, but there are issues. Check https://wiki.blender.org/wiki/Modules/Animation-Rigging/Weak_Areas#Selection_synchronisation_between_pose_bones_and_animation_channels
Sounds neat to me!
Sorry, I linked the wrong proposal. It should have been this one:
Show & isolate only the curves of the selected Bone in the graph editor by it's top node. — Right-Click Select
I think it illustrates what people mean by selecting a channel makes <it and its children>'s curve display, basically syncing channels' selection to their curves' visibility, with parent affecting children.
Though, for this to work optimally, that would also mean an option to disable selecting an object from selecting its channel in the graph. Right now, If I select Cube in the above example, it selects the Cube object and deselects the Camera, meaning I lose the Camera's channels from the channels list with the Graph's "Only Show Selected" filter. Which works, but could be used differently:
If we think of the graph's filters as "what channels to show in the channels list" and the channels' selection as "what curves to show in the graph", isolating channels from the object selection gives flexibility.
If it helps, I can make a new proposal on RCS to compile the whole thing ?
Edit: made one: Graph Editor - Synchronize Channels Selection to Curves Display — Right-Click Select
