Graph Editor: Curve drawing improvements
Confirmed, NormalPublicDESIGN
Problem: keyframe dots can be somewhat hard to see, especially behind the current frame marker line.
Proposal:
  • Change the default theme to draw the keyframe dots larger. The current theme draws at 6px, for modern displays this should probably be increased to 7-9px. It's probably better to defer a concrete choice for this until T68982: Graph Editor: UI Scale effect on Curves drawing is done.
  • Draw keyframe dots of selected keyframes on top of current frame line. Keep drawing unselected keyframe dots behind the line.
Sybren A. Stüvel (sybren) renamed this task from Curve drawing improvements to Graph Editor: Curve drawing improvements.Aug 21 2019, 3:59 PM
Sybren A. Stüvel (sybren) lowered the priority of this task from 90 to Normal.
Sybren A. Stüvel (sybren) created this task.
+1
  • Change Vertex Size theme property to 8px, looks nice and symmetric when the current frame line is on top.
  • Keyframes and handles should draw on top pf the current frame line.
@Pablo Vazquez (pablovazquez) do you intend to implement this? If not, feel free to unassign yourself or to assign to a developer who will implement it.
