Hair: changing children related settings not updating in particle editmode #69000
8 Participants
Reference: blender/blender#69000
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.73
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
Hair particle system children won't update/refresh in viewport when editing their parameters
bug1.blend
Added subscriber: @TarkanV
#76506 was marked as duplicate of this issue
#68655 was marked as duplicate of this issue
#71105 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Can confirm
Blender, you keep confusing me.
Did a little digging, and this seems to work:
P1076: #69000 part 1
What is still unclear to me is this:
Even without this, I can see this being done in objectmode:
And this is in particle editmode:
Seems to do the same stuff, no?
Also
BKE_particle_batch_cache_dirty_tag
is called for both... (as part ofBKE_object_eval_uber_data
)But edits just dont seem to come over to the correct ParticleSystems...
(this can go wrong the other way around as well: change children length in PE mode, then in OB mode --> go back to PE mode --> out of sync...)
Anyways, this all seem to be resolved by above patch (it seems)
Same is true for
EffectorWeights
btw. (changing those in particle editmode has no influence at all).Here I am not even sure if these should be displayed in PE mode (2.79 also didnt do this), and doing the correct update in
rna_EffectorWeight_update
might be tricky...This all being said, there might be a better way to do this, or this might not be look at at all (since new particles and hair are already on the way...)
This is the backtracke for deleting a whole particle, then Undo (cannot reproduce an Undo crash if I only delete a particle key...)
There, some ParticleCacheKey is broken...
Hair particle system refresh and crash problemto Hair: changing children related settings not updating in particle editmode (also crash when deleting a particle, then undo)Note the crasher on delete, undo is also fixed by D5755: Fix #68645: Hair Particle Edit - Particle Mirror crash when children are visible in the viewport
Added subscriber: @Floatharr
Added subscriber: @grosgood
@lichtwerk
Ah me. I can't connect the dot(s) from what I'm seeing to your August 21 musings.
Generally, what I'm seeing is AddressSanitizer catching a heap-buffer-overflow at particle.c:2549 in psys_thread_create_path. Just before falling into the abyss:
where:
But:
which offends the AddressSanitizer Gods.
A few lines up, at line 2549 where PTCacheEdit *edit is initialized, and from that pcache,
there seems to be a predicator of the buffer overflow in the bowels of *edit, in that the total point count exceeds the total cache count by one:
psys_thread_create_path() is a busy boy, being called once for each child particle in a head of hair. In the example blend file I'm debugging with (hair_bug.blend), there are four child hair particles, so four threads run: two for parent hair zero, and two for parent hair one. ChildParticle *cpa is set up by the caller, and its parent index reflects this relationship. In this simple setting, two threads will index a parent that isn't in the cache, and stuff hits the fan.
So the obvious thing is out-of-sync structures, and I surmise that your August 21 musings on dependency graphs stems from this out-of-sync-ness, which I trust you've seen in one form or another. I haven't confirmed these guesses, because it is getting late, there are dogs to walk, and tomorrow I am with clients. Ah me.
Blend file and other artifacts attached, which may be useful. Take care.
hair_bug.blend
hair_bug.blend
system-info.txt
**system-info.txt
address_sanitizer.txt
Debugger command line, to get dependency graph dumps and single-thread as much as possible.
@lichtwerk
For what it is worth, I applied D5912 & D5914 here - no longer seeing the buffer overwrite or total point count / total cache count disagreement. These look like a go. Gave me useful insights as well; thank you for that. Very much appreciate your work in this dusty old particle code. Thank you for that as well.
Added subscriber: @LucaDiCecca
Hair: changing children related settings not updating in particle editmode (also crash when deleting a particle, then undo)to Hair: changing children related settings not updating in particle editmodeCrasher is resolved, only missing update left for this report, updated report accordingly.
Will have a look at the patch again as it might some tweaking (totally forgot about this one).
Added subscriber: @rwman
Added subscriber: @Vyach
Added subscriber: @TheOldBen
Added subscriber: @aleksijuvani
