Escape key can not be binded
Closed, InvalidPublic
2.80
You can not bind ESC key in the upper box. Lower is working well. Another keys are working in the both.
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Waiting for Developer to Reproduce.Aug 22 2019, 12:02 PM
Assume this is because in the upper box the prop is drawn with full_event / UI_ITEM_R_FULL_EVENT. allowing to cancel...
Would think this is done intentionally?
CC @Campbell Barton (campbellbarton)
@Cenek Strichel (cenda) What you mean by ESC key can't be bind in upper box... however already assigned
@Abid Maqbool (cto.abid) : if I understood correctly, and you've already assigned this to something other than ESC, and you want to assign to ESC again, then this isnt working in the upper box, it will cancel instead (leaving it at the former assignment...)
Yes you can not bind ESC in upper box. It cancel the operation.
Adam Preisler (Alphisto) claimed this task.
Those two boxes are linked together. The lower one is only more detailed description. Closing this as invalid.
