EEVEE doesn't correctly render two SSS materials mixed with a mask
Closed, InvalidPublic
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.60
Using the EEVEE renderer, when attempting to mix two materials that have SSS with a Mask and a Mix Shader node, EEVEE will correctly render one, but not both SSS materials (it ignores the SSS on the second material)
Cycles renders this correctly - FWIW
Open the attached blend file. Go to Rendered View, alternate between Cycles and EEVEE.
Related Objects
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Aug 22 2019, 10:33 AM
@SecuoyaEx (SecuoyaEx) : thx for checking on this.
Will have to close since this is a known limitation...
Thanks for letting me know - and the link to the limitations page.
