Transform issue with the Item panel
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Hi, when I press N, a panel open on the right side of the viewport, there is a transform tab in this pannel. in blender 2.7x, when I scale/translate/rotate several objects with this pannel, it does for all the objects. In the 2.80, when I have several objects selected and change their values with this pannel, it only change the transform of the active element, instead of doing it for all the selected objects
Antonin (Antoninhs) renamed this task from Transform issue with the Item pannel to Transform issue with the Item panel.Aug 23 2019, 12:09 AM
Antonin (Antoninhs) created this task.
Antonin (Antoninhs) updated the task description. (Show Details)
The feature's still there; you just have to hold Alt while you're making adjustments.
Abid Maqbool (cto.abid) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Aug 23 2019, 5:28 AM
As asked, hold down Alt while editing the properties for multiple objects at a same time...
If instrusted you can see more here https://developer.blender.org/T54987
Let we know, if you get what you want?
Indeed, holding down alt does what I want, I didnt know that, thank you !
I think it would be more intuitive if it affect all the objects selected by default, and affect the active object while holding alt. And maybe let the user know that he can hold alt somehow.
Philipp Oeser (lichtwerk) closed this task as Resolved.Aug 30 2019, 3:09 PM
Thx @Abid Maqbool (cto.abid) for clearing that up.
Will close this then...
