Node sockets location bug after a keyframe is inserted #69127
Closed
opened 2019-08-24 22:34:19 +02:00 by Martin Schläpfer · 7 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
Broken: version: 2.81 (sub 3), branch: master, commit date: 2019-08-22 20:40, hash: 1de7717ed7
Worked: version: 2.81 (sub ?), branch: master, commit date: 2019-08-18 20:41, hash: 10001d9099
  • Factory Settings and default startup.blend
After inserting any type of keyframe for any object, node sockets in the node editor are no longer properly aligned to their respective values on a node.
When moving the editor view or a node itself, the sockets jump and flicker in close proximity to where they should be located.
Way 1:
  • Open Blender.
  • Select the default cube, camera or light.
  • Hit - and insert a keyframe (Loc, Rot, ...etc. doesn't matter).
  • Switch to the 'Shading' workspace and move the default Principled BSDF of the default cube around to see the bug.
    Way 2:
  • Open Blender.
  • Switch to the 'Shading' workspace and select an object in the 3D-view.
  • Selecting the default cube and moving the default Principled BSDF around, everything seems fine.
Switch back to the 'Layout' workspace and right after that switch again, back to the 'Shading' workspace: Same result as in way 1.
  • The bug affects all node editors, not just the Shader editor.
**System Information** Operating system: Windows-10-10.0.17763 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70 **Blender Version** Broken: version: 2.81 (sub 3), branch: master, commit date: 2019-08-22 20:40, hash: `1de7717ed7` Worked: version: 2.81 (sub ?), branch: master, commit date: 2019-08-18 20:41, hash: `10001d9099` * Factory Settings and default startup.blend **Short description of error** After inserting any type of keyframe for any object, node sockets in the node editor are no longer properly aligned to their respective values on a node. When moving the editor view or a node itself, the sockets jump and flicker in close proximity to where they should be located. **Exact steps for others to reproduce the error** **Way 1:** - Open Blender. - Select the default cube, camera or light. - Hit - [x] and insert a keyframe (Loc, Rot, ...etc. doesn't matter). - Switch to the 'Shading' workspace and move the default Principled BSDF of the default cube around to see the bug. **Way 2:** - Open Blender. - Switch to the 'Shading' workspace and select an object in the 3D-view. - Hit - [x] and insert a keyframe (Loc, Rot, ...etc. doesn't matter). - Selecting the default cube and moving the default Principled BSDF around, everything seems fine. # Switch back to the 'Layout' workspace and right after that switch again, back to the 'Shading' workspace: Same result as in way 1. * The bug affects all node editors, not just the Shader editor.
Added subscriber: @Ashpaw
Member
Added subscriber: @EAW
Member
I can confirm using Way 1 that this is indeed broken in 1de7717ed7
The sockets appear to be snapped to the background grid when the node is moved around.
I can confirm using **Way 1** that this is indeed broken in 1de7717ed7 The sockets appear to be snapped to the background grid when the node is moved around. ![Nodes.jpg](https://archive.blender.org/developer/F7702409/Nodes.jpg)
Member
Added subscriber: @CharlieJolly
Member
Missing setting ViewportSize fixes this
introduced in 2ba233a31f
diff --git a/source/blender/editors/space_node/node_draw.c b/source/blender/editors/space_node/node_draw.c
index 642f90407fe..6dc2182b684 100644
--- a/source/blender/editors/space_node/node_draw.c
+++ b/source/blender/editors/space_node/node_draw.c
@@ -951,6 +951,7 @@ void node_draw_sockets(View2D *v2d,
   GPU_program_point_size(true);
   immBindBuiltinProgram(GPU_SHADER_KEYFRAME_DIAMOND);
   immUniform1f("outline_scale", 0.7f);
+  immUniform2f("ViewportSize", -1.0f, -1.0f);
   /* set handle size */
   float scale;
Missing setting ViewportSize fixes this introduced in 2ba233a31f ``` diff --git a/source/blender/editors/space_node/node_draw.c b/source/blender/editors/space_node/node_draw.c index 642f90407fe..6dc2182b684 100644 --- a/source/blender/editors/space_node/node_draw.c +++ b/source/blender/editors/space_node/node_draw.c @@ -951,6 +951,7 @@ void node_draw_sockets(View2D *v2d, GPU_program_point_size(true); immBindBuiltinProgram(GPU_SHADER_KEYFRAME_DIAMOND); immUniform1f("outline_scale", 0.7f); + immUniform2f("ViewportSize", -1.0f, -1.0f); /* set handle size */ float scale; ```
This issue was referenced by f2c3dc94b1
This issue was referenced by f2c3dc94b1cd0bed17863faa0c6044edb29d6566
Member
Charlie Jolly self-assigned this 2019-08-25 17:38:37 +02:00
Reference: blender/blender#69127
