Volumetrics Doesn't Apply to other meshes created with the Array Modifier #69149
Open
opened 2019-08-25 16:44:30 +02:00 by Daniel O'Loughlin · 5 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: f6cb5f5449
In evee, I have a cube with an array modifier and a volume scatter node in its material. The volume scatter only applies to the original object, not the objects created by the array modifier. However in cycles the volume scatter works as expected.
Create Cube with Fog material *see attached blend
Observe where the volume scatter takes effect when switching between evee and cycles.lighthouseEveeVolumetrics.png
FogBug.blend
**System Information** Operating system: Windows-10-10.0.18362 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70 **Blender Version** Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: `f6cb5f5449` Worked: (optional) **Short description of error** In evee, I have a cube with an array modifier and a volume scatter node in its material. The volume scatter only applies to the original object, not the objects created by the array modifier. However in cycles the volume scatter works as expected. **Exact steps for others to reproduce the error** Create Cube with Fog material *see attached blend Observe where the volume scatter takes effect when switching between evee and cycles.![lighthouseEveeVolumetrics.png](https://archive.blender.org/developer/F7703152/lighthouseEveeVolumetrics.png) ![lighthouseCyclesVolumetrics.png](https://archive.blender.org/developer/F7703151/lighthouseCyclesVolumetrics.png) [FogBug.blend](https://archive.blender.org/developer/F7703150/FogBug.blend) [Based on the default startup or an attached .blend file (as simple as possible)]
Added subscriber: @danothemen
Added subscriber: @AbidMaqbool
Same happens in Blender 2.81 af8e8be7b1 too
Added subscriber: @fclem
Volumetric objects in EEVEE are using the texture space (editable in the mesh data panel) as a bounding box. Anything outside will not be rendered.
This is a known limitation. There is no plan to remove it for now.
Volumetric objects in EEVEE are using the texture space (editable in the mesh data panel) as a bounding box. Anything outside will not be rendered. This is a known limitation. There is no plan to remove it for now.
Philipp Oeser removed the
label 2023-02-09 15:15:20 +01:00
Reference: blender/blender#69149
