Bug line 524, line 83 #69152
Reference: blender/blender#69152
Operating system: Windows 10
Graphics card: AMD A8-3500M APU with Radeon(tm) HD Graphics 1.50 Ghz
Broken: 2.80
Hello! Help solve the problem. The problem starts because if I start to actively use third-party add-ons, although after the program is completely reset to the initial settings, the problem disappears only for a while. Later, an error appears when trying to select an object in the scene.
I enclose the error text:
SyntaxError: invalid syntax
Added subscriber: @Yura-4
Added subscriber: @Mets
Load Factory Settings is only temporary. To save the factory settings as your permanent settings, you need to go into user preferences and manually save preferences. Does this help?
Preserved basic. Hope this helps. Is the error code related to the fact that I use addons?
The error is not directly in an addon, but it looks like a rather mysterious error to me, so I can't be sure. Try reinstalling your addons one by one and see if any of them break it.
Added subscriber: @lichtwerk
This most likely is a duplicate of #65397 (Assigning shortcut to editor properties gives errors).
Assigning a shortcut might have happened manually or through an addon.
In any way, this should not throw an error, but is already high on the priority list...
Will merge this report into #65397...
Closed as duplicate of #65397
