'Make Links -> Modifiers' ignores Hooks #69189
Reference: blender/blender#69189
Win 7x64, Gtx580,
Ubuntu 16 x64, Intel Gma 500
Blender 2.8
Not sure it's a bug, but couldn't find any mentions of a deliberate limitation.
Copying modifiers (Make Links -> Modifiers) leaves out Hook modifiers (including for identical and data linked objects).
hook2.blend
Added subscriber: @KonstantinsVisnevskis
#74615 was marked as duplicate of this issue
Added subscriber: @lichtwerk
This is explicitly disabled in code, so would not be considered a bug.
(Since the modifier stores data specific to the mesh / vgroup this could lead to unpredictable results if just copied to other objects -- it could work in some cases but would cause confusion if it doesnt for other cases...)
There is also the the
Copy Attributes Addon
which generally does copy the modifier (but this skips the neccessary data mentioned above, so it is basically not usable for the hook modifier either...)Sorry to say, but in this case the only workaround to setting this up manually is to script the workflow using python...
Will close this as not-a-bug, but feel free to comment again if issues persist...
Thanks, I'll probably find a work-around, but just to give an example - in my case there are 160 objects with linked data. Although it's probably possible to do some check on whether the data is compatible, I actually wasn't expecting that due to potential nuances. But what also wasn't expected is skipping the modifier alltogether, as it could skip just the hidden vertex binding list, still removing the majority of clicking work.
@KonstantinsVisnevskis: if I understand correctly, try
Copy Attributes Menu
then:Ctrl
+C
>Copy Modifiers
Thank you. That indeed worked.
Added subscriber: @SergeL
Why not to add a warning message about it, somewhere in the menu? It really feels like software fault rather than precaution and with long modifier stacks and linked objects it is very easy to miss things like that
Added subscriber: @karja
