Alembic Import: Visibility #69191
13 Participants
Reference: blender/blender#69191
Operating system: Microsoft Windows 10 Pro, 10.0.18362 Build 18362
Installed Physical Memory: 64.0 GB
Graphics card: NVIDIA GeForce GTX Titan Black, Driver 26.21.14.3064
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
, type: build date: 2019-07-29, 09:44 AMShort description of error
When importing Alembic files, visibility is not recognized by Blender as it is in other 3D applications. This is important when using multiple proxy objects in another application that need to be invisible when imported.
Example Alembic with Visibility
Alembic_Visibility.abc
Blender does not recognize the Visibility properties
Example Blend file with Example Alembic attachment above
Alembic_Visibility.blend
Implementation of other Alembic Properties may also be considered as in Cinema 4D's Alembic Import Dialog
{F7705176}
Added subscriber: @KevinCBurke
Added subscriber: @AbidMaqbool
Latest Blender 2.81
ce2368cf69
same behavior...IMO, not a bug/error yet a feature/improvement or so on..
Added subscribers: @dr.sybren, @lichtwerk
In a way this is similar to the lack of importing e.g. Focal Length (#54050 (Alembic: Camera properties (focal length, focus distance, ...) animation not importing)), or Custom Properties (#50725 (Alembic export doesn't take 'Custom Properties', as alembic non-standard data.)).
Right now, Alembic in blender is based on modifiers and constraints, so that streaming will work and everything is updated when the .abc gets updated (well not entirely, but almost).
So (for me), this looks like a similar problem: If support for visibility is to come, it should work with something like D2324: Alembic: F-Curve cache modifier to lookup arbitrary property animations. (supporting animations and doing the disc read automatically without the need to reload an .abc manually if anything in there changed...).
@dr.sybren: what do you think? Of course reading visibility once could be an option [but I think the F-Curve cache modifier sounds like the way to go, no?]
That all being said, this is not really a bug, but a feature request, question is if we keep this as TODO for {#69058}?
Will let @dr.sybren decide...
Added subscriber: @SerjMaiorov
We have the same problem:
Rig Test_02-Comparison.mp4
As you can see, the rigger used "Write visibility" option to swap between face parts. In Blender - all planes are visible.
Here are the Alembic file and the texture for the swapping face parts.
dad7.abc
Moreover, in the beginning, the rigger used moving UV's as a way to stay with the same plane and still swap between the faces texture grid, but it also didn't work in Blende...
This is indeed not a bug, it's simply a property that's written to Alembic and that's not read by Blender. Alembic is quite bad in this respect, in that there is no well-documented open standard in which such properties are defined. I'd be very happy if you can prove me wrong on this one.
Features like this one and the others @lichtwerk mentioned should probably wait until #69046 (Cache loading via animation system) has been implemented. That will give us a much better way to load arbitrary properties from Alembic.
Added subscriber: @PixelTrader
Added subscriber: @LukasStockner
In case anyone's interested, here's a quick and dirty patch for importing static visibility: P1264
Does not support animated visibility or reloading when the file changes due to the mentioned design challenges.
So exciting to see progress on this!!!!!
This comment was removed by @KevinCBurke
Added subscriber: @zrp
Added subscriber: @Mentales
Added subscriber: @ChrisR-2
This issue has been flagged more than 3 years ago and it's a real show stopper in VFX. Badly need a fix please
Is there any progress or plans for this issue?
Currently there is no way to send visibility keyframe animations.
USD is not possible either. The problem is even worse when importing a scene into blender with complex visibility animations.
This is one of the hardest parts of using Blender in production.
It becomes too much of a problem when importing scenes animated in other DCCs into Blender for lighting and rendering.
Is there a solution for this? No news..
