Scatter Objects. #69194
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#69194
Windows 10 Pro 64 Bit
Graphics card:
RTX 2080ti+RTX 2070+GTX 1070+GTX 1070.
Broken: blender-2.81.0-git.277875492564-windows64 . Blender 2.80 official release 2.80.75
Worked: It seems to be working on this version on Youtube.https://www.youtube.com/watch?v=yAOuZBzEF8E - ver 2.80.53
Results are not as expected.
Bug One.
Start with default cube and move G,Y,9 .
Add Plane and scale S,8 .
Select Cube then Shift Select Plane .
Search- F3,Scatter Objects .
Draw on the plane. Press Enter .
Objects are scattered on the Plane correctly but the original scatter object(Cube) is also drawn at 0,0,0 .
Bug Two.
Repeat the steps above but Apply>All Transforms to Plane and Cube before Scatter Objects command.Press Enter.
Object at 0,0,0 no longer appears but the objects are scattered all over the place above and below the Plane.
Bug Three.
The Scatter controls in the 'N' toolbar cannot be changed while the Scatter command is running. The Scatter controls in the Properties>Active Tool and Workspace Settings tab work as expected.
Thanks.
Added subscriber: @stevensmith
Added subscriber: @AbidMaqbool
IMO! No bug/error here...
1. Original Cubeis also on Center (Cube - copy) IMO,
Scatter Objects Plugins
works as this manners2. When you apply transform for
Plane
no affects at all, but when same for Cube, it's origin is effected (set to center of Viewport)... and objects on scattering is placed from origin of every objects3. Often During specific operation (e.g. Circle Select
C
) Blender tries to isolate whole editor so that's is why you can't control values from within Viewports -> Numeric Panel... IMO it's expected behaviorScattering Object Startup Template.blend
Ahh. I see now. My bad.
Thanks for your time and help.
Added subscriber: @lichtwerk
thx @AbidMaqbool for clearing that up, lets close this then...
