Outliner Sync Selection: Use general update method #69212
Open
opened 2019-08-27 14:13:43 +02:00 by Campbell Barton · 6 comments
Currently there is a callback to flag the wmWindowManager as needing selection to sync to the outliner ED_outliner_select_sync_from_object_tag.
Using this requires us to explicitly tag on any selection change. See: D5572: Outliner synced selection refinements.
We currently have 2x function calls used when objects have been selected.
DEG_id_tag_update(&scene->id, ID_RECALC_SELECT);
WM_event_add_notifier(C, NC_SCENE | ND_OB_SELECT, scene);
This task is to solve selection tagging in a more general way.
Possible solutions could be:
  • Use the depsgraph tag or notifier to tag the outliner for selection syncing.
  • Add a function that calls DEG_id_tag_update, WM_event_add_notifier & ED_outliner_select_sync_from_object_tag so we don't need to duplicate the same lines of code in many places.
Note, object selection is used for the purpose of discussion. Selection of other types may use a similar method.
Currently there is a callback to flag the `wmWindowManager` as needing selection to sync to the outliner `ED_outliner_select_sync_from_object_tag`. Using this requires us to explicitly tag on any selection change. See: [D5572: Outliner synced selection refinements](https://archive.blender.org/developer/D5572). We currently have 2x function calls used when objects have been selected. ``` DEG_id_tag_update(&scene->id, ID_RECALC_SELECT); WM_event_add_notifier(C, NC_SCENE | ND_OB_SELECT, scene); ``` This task is to solve selection tagging in a more general way. Possible solutions could be: - Use the depsgraph tag or notifier to tag the outliner for selection syncing. - Add a function that calls `DEG_id_tag_update`, `WM_event_add_notifier` & `ED_outliner_select_sync_from_object_tag` so we don't need to duplicate the same lines of code in many places. ---- *Note, object selection is used for the purpose of discussion. Selection of other types may use a similar method.*
Author
Owner
Added subscribers: @ideasman42, @Sergey, @mont29, @brecht, @dfelinto
Added subscriber: @natecraddock
I think that using the depsgraph or notifiers would be the better route. A quick look through the code where ED_outliner_select_sync_from_ calls are made shows that the notifiers are more common than depsgraph tags (especially with bone selection).
I think that using the depsgraph or notifiers would be the better route. A quick look through the code where `ED_outliner_select_sync_from_` calls are made shows that the notifiers are more common than depsgraph tags (especially with bone selection).
Author
Owner
Talked with @Sergey and this doesn't fit with the depsgraph either (since this is screen data and not something the depsgraph should be concerned with).
Neither of the existing systems are well suited to this, we agreed it would be best to add a function that wraps all 3 function in a single call, eg: ED_object_select_update
Talked with @Sergey and this doesn't fit with the depsgraph either (since this is screen data and not something the depsgraph should be concerned with). Neither of the existing systems are well suited to this, we agreed it would be best to add a function that wraps all 3 function in a single call, eg: `ED_object_select_update`
Would we also want general functions for bone and sequence selection to tag for syncing, depsgraph, and notifiers?
Author
Owner
Yes, a function for each type seems reasonable.
Nathan Craddock self-assigned this 2019-09-20 18:14:47 +02:00
Philipp Oeser removed the
label 2023-02-10 08:54:21 +01:00
2 Participants
Reference: blender/blender#69212
