Blender will not start because of some conflict with my computer's administrator. I am the only user and administrator.
Closed, InvalidPublic
Operating system: Windows 10
Graphics card:NVIDIA GeForce GTX 750 Ti
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
The installer has insufficient privileges to access this directory: C:Users\Bill\AppData\Roaming\Microsoft\Installer\{F343C69A-4ABA-434C-9C73-12A519D269CD}, The installation cannot continue, Log on as administrator or contact your system administrator.
I AM the administrator and only user of this computer yet I get this when trying to load Blender;
clean up your system and reinstall blender as normal user, better if you download .zip file and avoid to install it as showed so well in requirement page
Before making a new error report, the use of the 'Search' box (top right on the BugTracker Reporting page) is very much appreciated to check if the errors / problems have already been reported by other users, every minute you dedicate at this is a minute earned by the developer to fix bugs. The duplication of the bugreport is a waste of time and resources for the developers
Thank You
Recommended why is @dark999 (dark999) suggests
However, I think, running installer as Run as Administrator may resolve privileges problem
Jean First (robbott) changed the task status from Unknown Status to Unknown Status.Dec 4 2019, 1:50 AM
Jean First (robbott) claimed this task.
I believe this is not a blender problem. Please try with the latest blender from https://builder.blender.org/download and reopen this ticket if this problem still occurs.
