vertex slide operation is corrupted
Closed, DuplicatePublic
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
[if you have a simple grid, you choose one or more vertex, you run the command vertex slide (shift V) the following is noted:
while running the command, if you alter any option of that command while running, this does not get reflected in the dialog box that shows after finishing the command
if you alter the Even option in dialog box after the command, this corrupts the locations of the affected vertices{F7707606} ]
Can confirm this...
Exact Steps:
  • Pick a simple object, e.g. Grid (Add -> Mesh -> Grid)
  • In Edit Mode, select some vertices
  • Slide Vertices (Shift + V)
  • Apply some options e.g. Even (E) or Clamp (C)
Redo Panel not effected:
This is actually a duplicate of T45964, will merge these reports...
