Parent Path constraint confusion
Closed, InvalidPublic
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.60
Broken: version: 2.81 (sub 3), branch: master, commit date: 2019-08-24 15:59, hash: rB6bb2912704ba
This all belongs somehow to each other.
Parent - Follow Path does not add a Follow Path constraint. The functionality is there. But the constraint is missing in the constraints settings panel in the properties editor.
Parent - Path Constraint does not add a path constraint, but a AutoPath constraint that has the same functionality than Follow Path constraint. And might be in fact a Follow Path constraint.
AutoPath constraint is not in the list of constraints. And so once removed you can't add it back from the list of constraints.
AutoPath constraint is not documented.
Create an object. Create a curve. Parent the cube to the curve with Follow Path. The functionality is there. But the constraint will not appear at the cube in its constraints list. Means you cannot change the curve afterwards.
Create an object. Create a curve. Parent the cube to the curve with Path Constraint. The AutoPath constraint will be added. Looks similar to Follow Path. And when it's really the same then we might have one operator too much in the parent menu.
True, it is a special kind a parent relationship, object is parented to the curve which has Path Animation turned on in its data tab
https://docs.blender.org/manual/en/dev/modeling/curves/properties/path_animation.html
Not 100% sure what you mean, but on first sight this seems wrong, you can change the curve afterwards...
It is a Follow path constraint, it just has its name changed...
https://docs.blender.org/manual/en/dev/animation/constraints/relationship/follow_path.html
See above, doesnt apply, just use the Follow Path constraint (documentation)
I agree naming in the menu could be a bit clearer [Follow Path could be Parent Follow Path, Path Constraint could be Follow Path Constraint -- but it is not wrong really and will not be considered a bug]
Will have to close this, feel free to comment though if issues persist...
CC @William Reynish (billreynish)
