Adding shortcuts to "Show in viewport (screen icon)" causes error #69293
Reference: blender/blender#69293
Operating system:
macOS Mojave 10.14.6 (18G95)
MacBook Pro (Retina, 13-inch, Mid 2014)
Processor: 2.6 GHz Intel Core i5
Graphics: Intel Iris 1536 MB
Broken: Version 2.80 (2.80 2019-07-29)
If you add a shortcut to the "Show in viewport (screen icon)" for the modifiers, it only works for that instance & if you delete the modifier and use the shortcut it gives an error (see attached image)
1/ Launch Blender, add "subdivision surface" to the default cube.
2/ Right click on "Show in viewport icon" and assign a shortcut eg command k
3/ add another "subdivision surface" modifier
4/ Use shortcut and only the first instance of the modifier toggles on and off. Shouldn't these be global shortcuts affecting each one? This also applies if you add it to the Quick favorites menu (only works for that instance of the modifier).
5/ Delete both modifiers
6/ use the shortcut again and you get the error
Hope that helps,
Have a good day
Added subscriber: @kuzey
Added subscriber: @lichtwerk
This looks like a duplicate of #65397
Closed as duplicate of #65397
Added subscriber: @AbidMaqbool
IMO, It's bugs or not!
But want to puts some light on it (no worry about, torch will be mine!!!).
You can assign short-cuts to both sub-surface separately:
e.g. Add sub-serface and assign short-cut (j) & add second sub-surface and assign short-cut (k)
When the guy on which short-cut is applied, it's will give error! (it's simple)
