texture glitch
Closed, InvalidPublic
Operating system: windows 10
Graphics card: gtx 1060 3gb
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
when i press the ctrl + z all the textures change or bug its werd
when a take a model there is alredy textures, after i play with it and do things and i pressed the ctrl + z alot of times then all the textures changed like the texture of the hair became the texture of the body, the face became the texture of the hair EXC.
You should specify version of Blender you're using and attach your .blend file. Also make sure your graphic drivers are up to date. Always use Help menu to report your bugs.
Here's a good tutorial.
Abid Maqbool (cto.abid) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Sep 1 2019, 10:16 AM
