repeated crashhes #69380
Reference: blender/blender#69380
Operating system:
Graphics card:
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (optional)
Added subscriber: @res02h3d
Switching to fully guarded memory allocator.
Blender 2.80 (sub 75)
Build: 2019-07-29 09:44 AM Windows
argv- [x] = blender
argv- [x] = --debug
argv- [x] = --debug-gpu
argv- [x] = --python-expr
argv- [x] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\PATRIC~1\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
Read prefs: C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
read file
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
Using KHR_debug extension
GL application marker: Successfully hooked OpenGL debug callback.
found bundled python: C:\Program Files\Blender Foundation\Blender\2.80\python
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1515, h : 26, d : 0, comp : 4, size : 0.15 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 8192, h : 128, d : 0, comp : 1, size : 1.00 MiB
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (2), and GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 3 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) will use SYSTEM HEAP memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GPUTexture: create : TEXTURE_2D, RGBA8, w : 405, h : 26, d : 0, comp : 4, size : 0.04 MiB
GL API other: Buffer detailed info: Buffer object 4 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1920, h : 20, d : 0, comp : 4, size : 0.15 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 333, h : 26, d : 0, comp : 4, size : 0.03 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 630, d : 0, comp : 4, size : 0.07 MiB
GL API other: Texture state usage warning: Texture 0 is base level inconsistent. Check texture size.
GL API performance: Program/shader state performance warning: Fragment Shader is going to be recompiled because the shader key based on GL state mismatches.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 304, h : 630, d : 0, comp : 4, size : 0.73 MiB
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), and GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GPUTexture: create : TEXTURE_2D, R8, w : 8192, h : 256, d : 0, comp : 1, size : 2.00 MiB
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), and GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GPUTexture: create : TEXTURE_2D, RGBA8, w : 333, h : 286, d : 0, comp : 4, size : 0.36 MiB
GL API other: Buffer detailed info: Buffer object 5 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 6 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1586, h : 26, d : 0, comp : 4, size : 0.16 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1586, h : 48, d : 0, comp : 4, size : 0.29 MiB
GL API other: Buffer detailed info: Buffer object 7 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 8 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 9 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 58, h : 868, d : 0, comp : 4, size : 0.19 MiB
GL API other: Buffer detailed info: Buffer object 10 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1528, h : 868, d : 0, comp : 4, size : 5.06 MiB
GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 1528, h : 868, d : 0, comp : 1, size : 5.06 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 257, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 256, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1528, h : 868, d : 0, comp : 3, size : 5.06 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1528, h : 868, d : 0, comp : 1, size : 5.06 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1528, h : 868, d : 0, comp : 2, size : 5.06 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 64, h : 64, d : 0, comp : 4, size : 0.06 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1528, h : 868, d : 0, comp : 1, size : 3.79 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1528, h : 868, d : 0, comp : 1, size : 2.53 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 527, h : 491, d : 0, comp : 4, size : 0.99 MiB
GL API other: Buffer detailed info: Buffer object 199 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STATIC_DRAW) will use VIDEO memory as the source for buffer object operations.
Saved session recovery to 'C:\Users\PATRIC~1\AppData\Local\Temp\quit.blend'
ModuleNotFoundError: No module named 'mocap'
ModuleNotFoundError: No module named 'io_blend_utils'
ModuleNotFoundError: No module named 'io_mesh_pdb'
ModuleNotFoundError: No module named 'io_convert_image_to_mesh_img'
ModuleNotFoundError: No module named 'io_import_gimp_image_to_scene'
ModuleNotFoundError: No module named 'object_animrenderbake'
ModuleNotFoundError: No module named 'animation_animall'
ModuleNotFoundError: No module named 'materials_utils'
ModuleNotFoundError: No module named 'mesh_custom_normals_tools'
ModuleNotFoundError: No module named 'uv_bake_texture_to_vcols'
ModuleNotFoundError: No module named 'uv_magic_uv'
ModuleNotFoundError: No module named 'uv_texture_atlas'
ModuleNotFoundError: No module named 'space_view3d_display_tools'
ModuleNotFoundError: No module named 'io_import_scene_lwo'
ModuleNotFoundError: No module named 'io_mesh_raw'
ModuleNotFoundError: No module named 'space_clip_editor_autotracker'
ModuleNotFoundError: No module named 'netrender'
ModuleNotFoundError: No module named 'io_scene_x'
ModuleNotFoundError: No module named 'ui_layer_manager'
ModuleNotFoundError: No module named 'space_view3d_brush_menus'
archipack: ready
Blender quit
Press any key to exit . . .
Blender 2.80 (sub 75) System Information
Blender:
version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
, type:build date: 2019-07-29, 09:44 AM
platform: Windows
binary path: 'C:\Program Files\Blender Foundation\Blender\blender.exe'
build cflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP -openmp
build cxxflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc -openmp
build linkflags: /MACHINE:X64 /SUBSYSTEM:CONSOLE /STACK:2097152 /INCREMENTAL:NO /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Python:
version: 3.7.0 (default, Aug 26 2018, 16:05:01) [MSC v.1900 64 bit (AMD64)]
paths:
'C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons_contrib'
'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons'
'C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons'
'C:\Program Files\Blender Foundation\Blender\2.80\scripts\startup'
'C:\Program Files\Blender Foundation\Blender\2.80\scripts\modules'
'C:\Program Files\Blender Foundation\Blender\python37.zip'
'C:\Program Files\Blender Foundation\Blender\2.80\python\DLLs'
'C:\Program Files\Blender Foundation\Blender\2.80\python\lib'
'C:\Program Files\Blender Foundation\Blender'
'C:\Program Files\Blender Foundation\Blender\2.80\python'
'C:\Program Files\Blender Foundation\Blender\2.80\python\lib\site-packages'
'C:\Program Files\Blender Foundation\Blender\2.80\scripts\freestyle\modules'
'C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\modules'
'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\modules'
Python (External Binary):
binary path: 'C:\Program Files\Blender Foundation\Blender\2.80\python\bin\python.EXE'
version: Python 3.7.0
Directories:
scripts:
'C:\Program Files\Blender Foundation\Blender\2.80\scripts'
'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\scripts'
user scripts: 'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\scripts'
pref scripts: None
datafiles: 'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\datafiles\'
config: 'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\config\'
scripts : 'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\'
autosave: 'C:\Users\Patrick DeFrancesco\AppData\Roaming\Blender Foundation\Blender\2.80\autosave\'
tempdir: 'C:\Users\PATRIC~1\AppData\Local\Temp\blender_a12876\'
FFmpeg:
avcodec: '58, 18, 100'
avdevice: '58, 3, 100'
avformat: '58, 12, 100'
avutil: '56, 14, 100'
swscale: ' 5, 1, 100'
SDL:
Version: 2.0.8
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
OpenColorIO: 1, 1, 0
OpenImageIO: 1, 8, 13
OpenShadingLanguage: 1, 9, 9
OpenSubdiv: 0, 0, 0
OpenVDB: 5, 1, 0
Alembic: 1, 7, 8
OpenGL:
renderer: 'GeForce G200/integrated/SSE2'
vendor: 'NVIDIA Corporation'
version: '3.3.0'
extensions:
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_clear_buffer_object
GL_ARB_color_buffer_float
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_bit_encoding
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXTX_framebuffer_mixed_formats
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_import_sync_object
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug
GL_KTX_buffer_region
GL_NVX_conditional_render
GL_NVX_gpu_memory_info
GL_NV_ES1_1_compatibility
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_explicit_multisample
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_half_float
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_buffer_load
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control
Implementation Dependent OpenGL Limits:
Maximum DrawElements Vertices: 1048576
Maximum DrawElements Indices: 1048576
GLSL:
Maximum Varying Floats: 60
Maximum Vertex Attributes: 16
Maximum Vertex Uniform Components: 4096
Maximum Fragment Uniform Components: 2048
Maximum Vertex Image Units: 32
Maximum Fragment Image Units: 32
Maximum Pipeline Image Units: 96
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41
OpenCL device capabilities:
Number of platforms: 1
Platform #0
Platform Name: NVIDIA CUDA
Platform Vendor: NVIDIA Corporation
Platform Version: OpenCL 1.1 CUDA 6.5.51
Platform Profile: FULL_PROFILE
Platform Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d9_sharing cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts
Number of devices: 1
Device: #0
Device Name: GeForce G200
Device Vendor: NVIDIA Corporation
Device OpenCL C Version: OpenCL C 1.0
Device Profile: FULL_PROFILE
Device Version: OpenCL 1.0 CUDA
Device Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d9_sharing cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics
Device Max clock frequency (MHz): 1100
Device Max compute units: 2
Device Max work group size: 512
CUDA device capabilities:
GeForce G200
CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_BLOCK 512
CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_X 512
CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Y 512
CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Z 64
CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_X 65535
CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Y 65535
CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Z 1
CU_DEVICE_ATTRIBUTE_MAX_SHARED_MEMORY_PER_BLOCK 16384
CU_DEVICE_ATTRIBUTE_SHARED_MEMORY_PER_BLOCK 16384
CU_DEVICE_ATTRIBUTE_TOTAL_CONSTANT_MEMORY 65536
CU_DEVICE_ATTRIBUTE_WARP_SIZE 32
CU_DEVICE_ATTRIBUTE_MAX_PITCH 2147483647
CU_DEVICE_ATTRIBUTE_MAX_REGISTERS_PER_BLOCK 8192
CU_DEVICE_ATTRIBUTE_REGISTERS_PER_BLOCK 8192
CU_DEVICE_ATTRIBUTE_CLOCK_RATE 1100000
CU_DEVICE_ATTRIBUTE_TEXTURE_ALIGNMENT 256
CU_DEVICE_ATTRIBUTE_GPU_OVERLAP 0
CU_DEVICE_ATTRIBUTE_MULTIPROCESSOR_COUNT 2
CU_DEVICE_ATTRIBUTE_KERNEL_EXEC_TIMEOUT 1
CU_DEVICE_ATTRIBUTE_INTEGRATED 1
CU_DEVICE_ATTRIBUTE_CAN_MAP_HOST_MEMORY 1
CU_DEVICE_ATTRIBUTE_COMPUTE_MODE 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_WIDTH 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_HEIGHT 32768
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_WIDTH 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_HEIGHT 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_LAYERS 512
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_WIDTH 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_HEIGHT 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_NUMSLICES 512
CU_DEVICE_ATTRIBUTE_SURFACE_ALIGNMENT 256
CU_DEVICE_ATTRIBUTE_CONCURRENT_KERNELS 0
CU_DEVICE_ATTRIBUTE_ECC_ENABLED 0
CU_DEVICE_ATTRIBUTE_TCC_DRIVER 0
CU_DEVICE_ATTRIBUTE_MEMORY_CLOCK_RATE 1332000
CU_DEVICE_ATTRIBUTE_GLOBAL_MEMORY_BUS_WIDTH 128
CU_DEVICE_ATTRIBUTE_L2_CACHE_SIZE 0
CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_MULTIPROCESSOR 768
CU_DEVICE_ATTRIBUTE_ASYNC_ENGINE_COUNT 0
CU_DEVICE_ATTRIBUTE_UNIFIED_ADDRESSING 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_WIDTH 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_LAYERS 512
CU_DEVICE_ATTRIBUTE_CAN_TEX2D_GATHER 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_WIDTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_HEIGHT 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH_ALTERNATE 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT_ALTERNATE 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH_ALTERNATE 0
CU_DEVICE_ATTRIBUTE_TEXTURE_PITCH_ALIGNMENT 32
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_WIDTH 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_WIDTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_LAYERS 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_WIDTH 4096
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_WIDTH 4096
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_HEIGHT 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_WIDTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_HEIGHT 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_DEPTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_WIDTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_LAYERS 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_WIDTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_HEIGHT 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_LAYERS 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_WIDTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_WIDTH 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_LAYERS 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LINEAR_WIDTH 134217728
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_WIDTH 65000
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_HEIGHT 65000
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_PITCH 1048544
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_WIDTH 8192
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_HEIGHT 8192
CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MAJOR 1
CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MINOR 1
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_MIPMAPPED_WIDTH 8192
CU_DEVICE_ATTRIBUTE_STREAM_PRIORITIES_SUPPORTED 0
CU_DEVICE_ATTRIBUTE_GLOBAL_L1_CACHE_SUPPORTED 0
CU_DEVICE_ATTRIBUTE_LOCAL_L1_CACHE_SUPPORTED 0
CU_DEVICE_ATTRIBUTE_MAX_SHARED_MEMORY_PER_MULTIPROCESSOR 16384
CU_DEVICE_ATTRIBUTE_MAX_REGISTERS_PER_MULTIPROCESSOR 8192
CU_DEVICE_ATTRIBUTE_MANAGED_MEMORY 0
CU_DEVICE_ATTRIBUTE_MULTI_GPU_BOARD 0
CU_DEVICE_ATTRIBUTE_MULTI_GPU_BOARD_GROUP_ID 0
Enabled add-ons:
io_scene_fbx (version: (4, 14, 14), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_scene_fbx_init_.py)
io_anim_bvh (version: (1, 0, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_anim_bvh_init_.py)
io_mesh_ply (version: (1, 0, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_mesh_ply_init_.py)
io_scene_obj (version: (3, 5, 9), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_scene_obj_init_.py)
io_scene_x3d (version: (2, 2, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_scene_x3d_init_.py)
io_mesh_stl (version: (1, 1, 3), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_mesh_stl_init_.py)
io_mesh_uv_layout (version: (1, 1, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_mesh_uv_layout_init_.py)
io_curve_svg (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_curve_svg_init_.py)
cycles (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\cycles_init_.py)
mocap (MISSING)
io_blend_utils (MISSING)
bone_selection_sets (version: (2, 1, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\bone_selection_sets.py)
camera_dolly_crane_rigs (version: (1, 1, 2), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\camera_dolly_crane_rigs.py)
camera_turnaround (version: (0, 3, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\camera_turnaround.py)
io_mesh_pdb (MISSING)
io_convert_image_to_mesh_img (MISSING)
io_import_gimp_image_to_scene (MISSING)
io_import_images_as_planes (version: (3, 2, 2), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_import_images_as_planes.py)
materials_library_vx (version: (0, 5, 8), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\materials_library_vx_init_.py)
mesh_looptools (version: (4, 6, 7), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\mesh_looptools.py)
mesh_relax (version: (1, 2, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\mesh_relax.py)
node_wrangler (version: (3, 35), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\node_wrangler.py)
pie_menus_official (version: (1, 1, 6), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\pie_menus_official_init_.py)
object_animrenderbake (MISSING)
rigify (version: (0, 5, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\rigify_init_.py)
object_skinify (version: (0, 11, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\object_skinify.py)
animation_animall (MISSING)
lighting_dynamic_sky (version: (1, 0, 6), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\lighting_dynamic_sky.py)
materials_utils (MISSING)
animation_add_corrective_shape_key (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\animation_add_corrective_shape_key.py)
space_view3d_math_vis (version: (0, 2, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_view3d_math_vis_init_.py)
object_print3d_utils (version: UNKNOWN, path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\object_print3d_utils_init_.py)
mesh_custom_normals_tools (MISSING)
system_blend_info (version: (0, 3, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\system_blend_info.py)
system_property_chart (version: (0, 1, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\system_property_chart.py)
uv_bake_texture_to_vcols (MISSING)
uv_magic_uv (MISSING)
uv_texture_atlas (MISSING)
space_view3d_3d_navigation (version: (1, 2, 5), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_view3d_3d_navigation.py)
space_view3d_display_tools (MISSING)
add_mesh_extra_objects (version: (0, 3, 3), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\add_mesh_extra_objects_init_.py)
io_import_scene_lwo (MISSING)
io_mesh_raw (MISSING)
space_clip_editor_autotracker (MISSING)
space_clip_editor_refine_solution (version: (1, 1, 5), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_clip_editor_refine_solution.py)
paint_palette (version: (0, 9, 4), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\paint_palette.py)
space_view3d_pie_menus (version: (1, 1, 9), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_view3d_pie_menus_init_.py)
render_auto_tile_size (version: (3, 1, 3), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\render_auto_tile_size.py)
netrender (MISSING)
io_scene_x (MISSING)
object_boolean_tools (version: (0, 4, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\object_boolean_tools.py)
add_mesh_BoltFactory (version: (0, 4, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\add_mesh_BoltFactory_init_.py)
ant_landscape (version: (0, 1, 8), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\ant_landscape_init_.py)
space_view3d_modifier_tools (version: (0, 2, 6), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_view3d_modifier_tools.py)
space_view3d_copy_attributes (version: (0, 4, 8), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_view3d_copy_attributes.py)
space_view3d_spacebar_menu (version: (1, 9, 3), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_view3d_spacebar_menu.py)
ui_layer_manager (MISSING)
measureit (version: (1, 8, 1), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\measureit_init_.py)
space_view3d_brush_menus (MISSING)
space_view3d_stored_views (version: (0, 3, 7), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\space_view3d_stored_views_init_.py)
archipack (version: (1, 2, 83), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\archipack_init_.py)
archimesh (version: (1, 2, 2), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\archimesh_init_.py)
io_scene_gltf2 (version: (0, 9, 36), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_scene_gltf2_init_.py)
lighting_tri_lights (version: (0, 1, 4), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\lighting_tri_lights.py)
magic_uv (version: (6, 1, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\magic_uv_init_.py)
blenderkit (version: (1, 0, 26), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\blenderkit_init_.py)
io_anim_nuke_chan (version: (1, 0), path: C:\Program Files\Blender Foundation\Blender\2.80\scripts\addons\io_anim_nuke_chan_init_.py)
Added subscriber: @rjg
Please add the file to your bug report instead of posting the entire log file as comment. You can either drag and drop it or use the cloud icon with the arrow to upload. Thank you!
Blender:
f6cb5f5449
platform: Windows
build system: CMake
Python:
paths:
Directories:
scripts:
pref scripts: None
FFmpeg:
SDL:
Version: 2.0.8
Other Libraries:
OpenSubdiv: 0, 0, 0
OpenVDB: 5, 1, 0
Alembic: 1, 7, 8
OpenGL:
version: '3.3.0'
extensions:
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_imaging
GL_ARB_multi_bind
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_robustness
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_rg
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_fog_coord
GL_EXT_gpu_shader4
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_lod
GL_EXT_texture_sRGB
GL_EXT_timer_query
GL_EXT_vertex_array
GL_KHR_debug
GL_NV_blend_square
GL_NV_copy_image
GL_NV_depth_clamp
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_gpu_program4
GL_NV_half_float
GL_NV_point_sprite
GL_S3_s3tc
GL_SGIS_texture_lod
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
GLSL:
Cycles:
Platform #0
Device: #0
GeForce G200
Enabled add-ons:
mocap (MISSING)
netrender (MISSING)
argv- [x] = blender
argv- [x] = --debug
read file
archipack: ready
Blender quit
That is still a comment and not an attached file.
Please edit your bug report using Edit Task to the right of your report.
Then upload the log file using the upload button and save the changes.
Added subscriber: @AbidMaqbool
Without nice readable report, we can't go forward.... sorry!!!
@res02h3d Please, modify your report as asked..
Follow template, which you will get From Blender :: Help -> Report A Bug
Put only very necessary info on front page. For extra info (e.g.
Help -> Save System Info
) attach files..Thanks!!!
Some tips: https://www.youtube.com/watch?v=JTD0OJq_rF4
Added subscriber: @mont29
