Click-and-Drag the Cursor with Snapping enabled and an Active Object selected missplaces the Cursor #69392
6 Participants
Reference: blender/blender#69392
Operating system: Linux-5.2.9-125.current-x86_64-with-glibc2.9 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.40
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash:
f6cb5f5449
Worked: None so far
Dragging the cursor and snapping it to a Vertex while having the Target set to Active makes the cursor snap to a point in space that is directly related to where you start your click-and-drag instruction in reference to the selected object's origin.
Important notes
If you deselect everything it works, but while there's an object selected the snapping won't work.
The problem also happens in Edit Mode, but only if there's an object selected in Object Mode. If you deselect everything in Object Mode and then go back to Edit Mode it works as intended.
As far as I can tell the offset of the snapping is directly related to where you start your click-and-drag in regards to the Objects Origin.
There's a BlenderArtist Topic in which some have tested the behavior in Blender 2.81: https://blenderartists.org/t/cursor-snapping-issue/1177897
I recorded a video showing the problem: blender_bug_report_complete.mkv
I also uploaded the blend file I used to record the video: bug_report_cursor_snapping.blend
Added subscriber: @AlienTux
#68265 was marked as duplicate of this issue
Added subscribers: @mano-wii, @lichtwerk
Looks like a bug to me.
The offset seems to be the negative distance between active object in relation to the snap element.
Makes sense if you actually have other objects selected, to me it doesnt really make sense for the cursor tool.
(In a way, snapping with active using the cursor doesnt really make sense to begin with, but...)
It is probably best to have no offset at all using the cursor.
@mano-wii: Would you agree?
(confirming for now with low prio...)
It may be better, but it is not the most correct.
Snap with
Active
indicates that you use the origin of the active object as the point to snap with.The problem here is that two operations are called: One when you click and other when you drag the cursor.
When you click with the mouse button, the 3d cursor is projected elsewhere.
Thus origin is no longer in the expected place when you drag, move and snap the 3d cursor.
This is a keymap issue, I'm not sure how to avoid this.
Added subscribers: @ziflin, @dr.sybren, @Patnard, @tomjk
Added subscriber: @Yianni
I've been finding this frustrating too. I usually have my Pivot Point set to Active Element and my snapping mode set to Center. Whenever I use the 3D cursor tool I have to change my Pivot Point to 3D Cursor in order to snap to where I want it - then change my pivot point back to Active Element.
I feel like the 3D Cursor tool should just ignore the Pivot Point you have set and always use the 3D Cursor as the Pivot Point.
Any updates on this? While 3DC dragging any other snapping option should be used to avoid such behaviour
