Can't zoom on 2D canvases by moving mouse left or right with ctrl+mmb
Closed, DuplicatePublicBUG
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.91
Broken: version: 2.81 (sub 4), branch: master, commit date: 2019-08-28 20:33, hash: rBa7ac8a22f8eb
Worked: 2.80
In 2.80 you could zoom on 2d canvases like the UV editor or the node editor holding Ctrl+mmd and moving the mouse left or right, or up or down, from the starting point
In 2.81 you can only zoom moving it up or down, left or right doesn't work. This makes it harder with tablets
On top of that, in the node editors, zooming in is slower than before and slower than zooming out, so if you zoom back and forth by moving the cursor between the same two positions, it averages to less zoom instead of zero zoom, which also happens on 2.80 but at a much slower rate
Open a new file, go to the shader editor and try zooming with ctrl+mmb, moving the cursor either side to side and up or down. Compare with 2.80
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Jan 9 2020, 9:32 PM
I can confirm both issues:
  • Can only zoom moving mouse up or down in uniform scale 2D spaces
  • In node editor zooming in is slower than out
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".Jan 15 2020, 5:43 PM
The first "issue" is by design, see "Zoom Axis" (Vertical/Horizontal) preference, T65837.
The second is a duplicate of T73575.
Yevgeny Makarov (jenkm) claimed this task.
See the comment above.
