New File Browser no longer automatically appends file extensions #69457
Closed
opened 2019-09-03 21:55:57 +02:00 by William Reynish · 10 comments
Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Plus Graphics 640 Intel Inc. 4.1 INTEL-12.9.22
Broken: version: 2.81 (sub 5), branch: master (modified), commit date: 2019-09-03 17:51, hash: 9e3cd98529
Previously, saving a Blender file would automatically add the file extension when you type in a fine name. This no longer works
  • New Blender file
  • File > Save As
  • type in a name, such as 'bob'
  • the .blend file extension isn't added (should be 'bob.blend')
**System Information** Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits Graphics card: Intel(R) Iris(TM) Plus Graphics 640 Intel Inc. 4.1 INTEL-12.9.22 **Blender Version** Broken: version: 2.81 (sub 5), branch: master (modified), commit date: 2019-09-03 17:51, hash: `9e3cd98529` Worked: (optional) **Short description of error** Previously, saving a Blender file would automatically add the file extension when you type in a fine name. This no longer works **Exact steps for others to reproduce the error** - New Blender file - File > Save As - type in a name, such as 'bob' - the .blend file extension isn't added (should be 'bob.blend')
Added subscriber: @WilliamReynish
Julian Eisel was assigned by William Reynish 2019-09-03 21:56:27 +02:00
Member
Added subscribers: @mont29, @brecht
Member
Okay, seems I went a bit fast with removing the old file/path button drawing... That was one of the first changes I did and months later, I forgot there were things to check on still...
By removing the C defined file/path text button drawing, I also (unintentionally) removed:
  • Auto completion for paths and file names
  • Additional handling applied on changes, like automatic extension appending (file_filename_enter_handle, file_directory_enter_handle)
  • Red highlight when the file name already exists
I can think of ways to address these (e.g. auto-complete callbacks for RNA, special handling through RNA set/update callbacks, etc), but some ugly hacks would be required. E.g. file_filename_enter_handle() needs a uiBut to function properly, which we can't pass from .py/RNA.
So right now I'm leaning towards moving the EXECUTE region drawing (buttons for file name, open and cancel) back to C. The file-path button (upper region) could be created through a layout template.
That way we could also bring back the fixed size Open and Cancel buttons, which we wanted anyway.
Any opinion @mont29 & @brecht?
Okay, seems I went a bit fast with removing the old file/path button drawing... That was one of the first changes I did and months later, I forgot there were things to check on still... By removing the C defined file/path text button drawing, I also (unintentionally) removed: * Auto completion for paths and file names * Additional handling applied on changes, like automatic extension appending (`file_filename_enter_handle`, `file_directory_enter_handle`) * Red highlight when the file name already exists I can think of ways to address these (e.g. auto-complete callbacks for RNA, special handling through RNA set/update callbacks, etc), but some ugly hacks would be required. E.g. `file_filename_enter_handle()` needs a `uiBut` to function properly, which we can't pass from .py/RNA. So right now I'm leaning towards moving the `EXECUTE` region drawing (buttons for file name, open and cancel) back to C. The file-path button (upper region) could be created through a layout template. That way we could also bring back the fixed size *Open* and *Cancel* buttons, which we wanted anyway. Any opinion @mont29 & @brecht?
Added subscriber: @StephenSwaney
This is a bad regression and should be fixed as soon as possible, preferably today.
Moving it to a template is fine with me.
This is a bad regression and should be fixed as soon as possible, preferably today. Moving it to a template is fine with me.
A template also sounds like a good solution to me…
Member
The template should work fine for the file-path button.
However for the buttons in the execute region (lower bar) I'd suggest moving them back to C entirely. We wanted to make the Open and Cancel buttons use a fixed width like previously, so they behave better on resize. The layout code doesn't allow me to do it. uiLayout.ui_units_x doesn't work as expected, some careful tweaks to the layout code would be needed and I don't really want to spend time on that.
It's an embarrassingly difficult problem, I've tried multiple things, but I don't see a different solution than having the entire region in C.
So, I'll just bring back C defined drawing code for the lower region, and add a template for the file path if there are no objections.
The template should work fine for the file-path button. However for the buttons in the execute region (lower bar) I'd suggest moving them back to C entirely. We wanted to make the *Open* and *Cancel* buttons use a fixed width like previously, so they behave better on resize. The layout code doesn't allow me to do it. `uiLayout.ui_units_x` doesn't work as expected, some careful tweaks to the layout code would be needed and I don't really want to spend time on that. It's an embarrassingly difficult problem, I've tried multiple things, but I don't see a different solution than having the entire region in C. So, I'll just bring back C defined drawing code for the lower region, and add a template for the file path if there are no objections.
Fine with me. I don't really care about having any of these buttons in Python, if it's easy why not, but it's not something we are tweaking all the time.
This issue was referenced by 45d4c92579
This issue was referenced by 45d4c925799e94c6d442a9a9066af2d3305724e1
Member
6 Participants
Reference: blender/blender#69457
