Manual: Archive 404 #69466
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#69466
The server redirect to the fallback on 404 and not to the 404 page within the archive.
example: https://docs.blender.org/manual/en/2.80/interface/splsh.html
404: https://docs.blender.org/manual/en/2.80/404.html
Added subscriber: @Tobias
Added subscriber: @dmcgrath
It would appear that we cannot use
ErrorDocument
Apache directives in a<Location>
context. To manually do this, we could have to define a hard-coded path for each language and version combination. Clearly this doesn't work well over time!As an alternative, I suggest that we use
.htaccess
files. I enabled theFileInfo
override for this path in Apache, so you should be able to drop an.htaccess
file in the document root for each language with the line:Where
<lang>
and<version>
are replaced accordingly.Part of the problem with custom error documents is that we also share a virtual host with the Python API, so it quickly becomes a problem to use a generic
404.html
page. No doubt, it would confuse a user accessing a non-existent PyDoc URL, only to have an English 404 page show up. Also, what about other languages?On a side note, Apache does have the ability to display MultiViews . Perhaps this could be useful?
I don't know anything about Apache.
Every language has it's own page, e.g. https://docs.blender.org/manual/fr/2.80/404.html
Create a file called
.htaccess
in the top directory of the output html files for the language with the contents:Changed status from 'Confirmed' to: 'Resolved'
