Alpha blend mode settings missing in look dev when using cycles #69481
2 Participants
Reference: blender/blender#69481
Graphics card: GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.36
Broken: version: 2.81 (sub 5), branch: master, commit date: 2019-09-04 00:01, hash:
da25aca267
When you're using cycles and have materials with alpha usage, it's not represented in the viewport. In Material tab -> no settings for blend mode.
BUT, you can switch to Eevee, make your alpha blend settings and then switch back to cycles and voila: it's also working.
In our current project we use Cycles, and there are many objects with transparent materials. And it's anoying to switch render engine for certain settings.
Here is Suzanne in a cube: alpha_viewport.blend
There is a second material with mixed shader (transparent + principled) as a "window", but you can't see suzanne, unless you switch to Eevee, material tab and set blend mode to alpha. It feels like a bug that you can only control material properties, that apply to the Cycles viewport, in another render engine.
Added subscriber: @SimeonConzendorf
Added subscriber: @Jeroen-Bakker
Has been fixed just an hour ago :-) So please check with the build of tomorrow.
68d1f09158
Thank you @Jeroen-Bakker for the hint - i checked the newest build and now the options are there.
Maybe the naming could be improved. Under Material there are "settings" - then under "viewport display" is another submenu "settings" - but aren't all these elements around "settings"?
