First selected object in Outliner is active one, while it is the last selected one that becomes active in 3DView #69505
7 Participants
Reference: blender/blender#69505
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.02
Broken: version: 2.81 (sub 5), branch: master, commit date: 2019-09-03 16:04, hash:
b3b59e3b56
The parenting behavior is backwards in the outliner. When parenting objects in the outliner, the active object becomes the child instead of the parent.
Create two objects and attempt to create a parent relationship using CTRL+P
Added subscriber: @foodi-4
Parneting behaviour is backwards in the outlinerto Parenting behaviour is backwards in the outlinerAdded subscriber: @lichtwerk
Not sure how you do this, afaict, there is no CTRL+P in the outliner...
Do you have this shortcut with Factory Settings as well?
Or did you add this yourself?
Which keyconfig are you using?
You're correct, you can't do CTRL+P in the outliner. I'm using default key config.
This was my sequence of events:
Make the selections in the outliner: select the child object, followed by the parent object, while holding down SHIFT.
Move the mouse cursor back to the 3D View, and hit CTRL+P>Object(Keep Transform)
The parent relationship is created, except it's backwards. The object selected first becomes the parent, instead of the child as you would expect.
Added subscribers: @WilliamReynish, @natecraddock, @JulianEisel, @mont29
@WilliamReynish @Zachman @JulianEisel Indeed in the outliner, the first selected object will be active one, while in 3DView it's always the last selected one that becomes active… Not sure whether we want to change that behavior or not?
Parenting behaviour is backwards in the outlinerto First selected object in Outliner is active one, while it is the last selected one that becomes active in 3DView@mont29 I guess we should make it consistent. It only really makes sense to parent the selected items to the active one I think.
@WilliamReynish parenting is totally unrelated to the issue here really… It just reveals the inconsistency in selection order (which confuses users):
@mont29 ah yes. @Zachman is working on exactly that, also so that walk selecting can change the active item. It required refactoring selecting vs activation.
I discussed this report earlier today with the author (he messaged me on Twitter). The real issue was the use of Shift+LMB for selection in the outliner. Shift is the modifier key for doing a range select. When there is an active outliner element, range select will not activate any elements. Ctrl is the modifier for extending selection + activation (equivalent to Shift click in 3D view).
So selecting in the outliner Cube.001 then Cube.002 with a Ctrl+click would indeed make the second selection (Cube.002) active.
Added subscriber: @reed2000
Added subscriber: @Jeroen-Bakker
Seems to work as expected. There is an inconsistency between CTRL and Shift but that is done by design.
