Animating particle lifetime effects all spawned particles in Cycles render
Confirmed, NormalPublicKNOWN ISSUE
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.70
Broken: version: 2.81 (sub 3), branch: master, commit date: 2019-08-26 09:27, hash: rB277875492564
I animate particle lifetime to control the flow of particles from an emitter (setting it to 1 to cut off the flow). Unfortunately even after baking particle dynamics rendering in Cycles will cause the whole system to cut off/die when the lifetime of the particles is animated to a value of 1. This doesn't happen in viewport or anywhere else; only during Cycles render.
Make particle system that has initial velocity from face(s), using an object for render.
Use keyframes to animate the particle lifetime with "constant" interpolation. Set the lifetime to 1 when you want to cut off the "flow" of particles.
In viewport this will look as expected and the existing particles will continue to exist while new particles have a lifetime of 1.
Bake dynamics.
Use Cycles render to render the animation: at the point that the animated value for lifetime is reached ALL particles emitted, old and new, are destroyed.
Casey (BagelCo) renamed this task from Animating particle lifetime effects all particles in Cycles render, even existing ones to Animating particle lifetime effects all spawned particles in Cycles render.Sep 4 2019, 10:18 PM
Casey (BagelCo) created this task.
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Jan 10 2020, 6:10 PM
Can confirm, that at the point that the animated value for lifetime is reached ALL particles emitted, old and new, are destroyed.
Regardless of render engine.
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".Jan 15 2020, 5:40 PM
Not sure whether that kind of animation is actually supposed to work… In any case, current particle system does not really have any maintainer, so considering this a s a known issue for now.
