intersect boolean tool does not remove face of main object that is being intersected.
Open, Needs Triage by DeveloperPublic
Graphics card: Intel(R) HD Graphics 620 Intel 4.5.0 - Build 22.20.16.4836
Tool does not create a through hole. I've been trying to make a hole in a cube that either goes through or bottoms out in the cube for 3 days now. For some reason I can not get the face of the cube to open up. The goal that I am trying to accomplish is a peg hole in a cube that enters the cube .5 inches and does not go through. I can not find any tool to accomplish this.
create a cube. use a cylinder to intersect the cube face and enter cube slightly. under faces tool button drop down menu in object mode with the cylinder placed slightly inside the cube. click in interse boolean tool and switch to intersect drop down. the modifier does not work either.
Stephen Swaney (stiv) triaged this task as Needs Information from User priority.
Sounds like you want Difference instead of Intersect.
A .blend showing what you are doing would be nice.
Jake H (iitsyaboijake) renamed this task from intersect boolean tool does not remove face of main object that is being intersected. does not create a through hole. ive been trying to make a hole in a cube that either goes through or bottoms out in the cube for 3 days now. for some reason i cannot get the face of the cube to open up. to intersect boolean tool does not remove face of main object that is being intersected. .
Jake H (iitsyaboijake) raised the priority of this task from Needs Information from User to Needs Triage by Developer.
I apologize, Im very new to blender.
