Run automated tests on buildbot
Confirmed, NormalPublicTO DO
Automated tests were enabled on buildbot.
  • Failure to pass tests should stop the build from being made available for download. We can do this after we verified tests are passing reliably.
  • Setup notifications for when buildbot master builds fail? Or just follow manually.
Revisions and Commits
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Normal.Sep 5 2019, 3:09 PM
Brecht Van Lommel (brecht) created this task.
Currently tests are only working on Linux. The issue is that the buildbot installs Blender to a directory separate from the build directory. However the tests run Blender from the build directory, and then will miss the Python executable on Windows and OpenMP library on macOS.
We need to either make the tests run from the install directory, or install Blender to the build directory.
Brecht Van Lommel (brecht) added a project: Restricted Project.Sep 8 2019, 12:25 PM
Tests are now passing on al platforms after rB2028302f4433: Tests: run tests from install path and some additional fixes.
