Eyedropper is not colormanaged hence gives incorrect result and useless #69549
Reference: blender/blender#69549
Operating system: Linux-3.10.0-957.10.1.el7.x86_64-x86_64-with-centos-7.6.1810-Core 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.56
Broken: version: 2.81 (sub 8), branch: master, commit date: 2019-09-05 10:52, hash:
b6e7e173ec
The eyedropper gives incorrect color sample on picking from viewport or image viewer.
What's the point of eyedropper while shading, if you get a different color from what you see?
Since the feature is broken, I consider it a bug, not a feature request.
Open the file attached.
The left image is a snapshot of the render from the right.
The bottom node is for sampling
Eyedrop from the render view or from the image and you'll get a different color from what you have in the top node.
eyedropper_color_management.blend
Added subscriber: @YegorSmirnov
Added subscriber: @EAW
It visually appears to be working to my eyes.
The top RBG node is just the orange color that you have plugged into the Emission slot of the Principled BSDF. Because you are using the Principled BSDF shader, the plane also has:
a white diffuse surface
that is being lit by a white light. The white light is to the right of the plane, aligned with the top edge, causing a gradient that is brightest on the top right and darkest on the bottom left.
The diffuse surface has a roughness of 0.5 so that white light is not all reflected evenly. This causes the variance of gradient color when examining the values on a per pixel basis I believe.
These four things combine to give the plane the color you see in the rendered view.
If you turn off the light or just use an emission shader, the color picker matches the top RGB node visually. It is only slightly different when you examine the individual values.
When rendering out your setup (principled with the light on), the emission pass is identical to the top RBG node.
Below I have attached my augmented version of your file. Just load it and hit F12 to render.
eyedropper_color_management2.blend
Does this make sense/fix your issue?
Oh, you are right! That was my mistake. Close that.
