Can't select geometry hidden by faces created by modifiers.
Open, Waiting for Developer to ReproducePublic
Operating system: Linux-4.15.0-60-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.116
Broken: version: 2.81 (sub 10), branch: master, commit date: 2019-09-09 20:20, hash: rB3e81c1c1d5fd
Worked: version: 2.80
  • Open the file:
  • Try to select vertex, in red circle:
Comments
In 2.80 you can select, in 2.81 - not.
Issue also in outer modifiers like Solidify, Displace
"On cage" option helps
Related Objects
@Brecht Van Lommel (brecht), in pre 2.80 versions, the occlusion was tested using the cage faces.
This behavior has been changed without much consideration.
Whether using the cage, or the final mesh, each case has its benefits.
I wonder if it's really better to go back to the previous behavior.
Of-course old behavior is better. For example, can you select this vertex:
Correct answer, not "Yes" or "No", but "only from specific camera distance". Is it not annoying?
In this behavior you never know can you select vertex or not
Philipp Oeser (lichtwerk) triaged this task as Waiting for Developer to Reproduce priority.Wed, Sep 11, 5:41 PM
