Follow Path constrainted does not work with deformed pathes
Open, Needs Triage by DeveloperPublic
Operating system: Windows 10 x64
Graphics card: Nvidia GTX 1060
Broken: 2.79b, 2.80 Release, 2.81 f3a4f12ac090
If there's an object with a Follow Path constraint, and the target path is deformed by a modifier, the object is not following the deformed path as expected. Instead, it follows the unmodified path.
  1. Open the attached blend file. There's a sphere with a Follow Path constraint. The sphere is correctly located at the start of the path.
  2. With object Curve1, reenable the curve modifier.
I expect the sphere to follow the deformed path, but it does not.
You will probably say it's by design or "not supported".
I say it's a bug because the sphere should follow the path where it is located obviously, not where it is not located.
