Laggy interface with highpoly sculpt and dyntopo
Closed, InvalidPublic
Operating system: Linux-5.0.0-27-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: AMD Radeon (TM) RX 460 Graphics (POLARIS11, DRM 3.31.0, 5.0.0-27-generic, LLVM 7.1.0) X.Org 4.5 (Core Profile) Mesa 18.3.0-rc4
Broken: version: 2.81 (sub 10), branch: master, commit date: 2019-09-10 22:12, hash: rB4ce3fbd52ae8
Blender voxel remesher works after using it on a setting of 0.01. I then switch into dynotop and blender freezes up. I then try to terminate the blender process using ksysguard. Blender becomes zombie and my computer freezes up.
Join the mesh pieces using the join operation. After this switch into sculpt mode and voxel remesh the mesh using a setting of 0.01. Then switch into dynotop mode and change the brush size. Try to rotate the view so the joints can be fixed. It should freeze up when trying to rotate the view.
I've included an attachment of the mesh that has given me trouble.
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Seems the file is missing...
I will try and upload the file again.
Philipp Oeser (lichtwerk) closed this task as Invalid.
Looks like this is just to heavy on resolution on your machine (maybe also related to that particular GPU and mesa?).
With a remesh of 0.01you are already at a facecount of ~4mill, turning on dyntopo on top will also lead to lags here (especially on the first viewport rotation, subsequent rotations are much smoother -- but certainly does not lead to a complete freeze), I am on linux with a 970m.
Would not consider this a bug, it is not related to the voxel remesher (same thing happens with just a subidivied cube at ~5mill faces).
Will close this as not-a-bug, but feel free to comment again if you still think you've found a bug...
Philipp Oeser (lichtwerk) renamed this task from Voxel remesher then dynotop crash. to Laggy interface with highpoly sculpt and dyntopo.Thu, Sep 12, 11:49 AM
