Denoising Albedo gives wrong results #69770
11 Participants
Reference: blender/blender#69770
Graphics card: GeForce GTX 1080 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.15
Broken: version: 2.81 (sub 10), branch: master, commit date: 2019-09-09 20:20, hash:
3e81c1c1d5
Denoising Albedo pass appears washed out
Open the following blend file and press F12
Albedo.blend
The Denoising albedo pass will come out like this
Lower the Principled Roughness value to 0 and press F12 again
This time the albedo looks correct
Switching to Metallic 1.0 and Roughness 0.5 looks like the albedo is completely lost
For the denoiser to give proper results, the Denoiser Albedo pass would need to give clean colors, not washed out colors.
Added subscriber: @zanqdo
Added subscribers: @Stefan_Werner, @JacquesLucke
While it is true that the Denoising Albedo looks washed out, it does not seem to be an issue. Using the Denoise node with it works just fine. Or do you get any issue with the denoising?
@Stefan_Werner Can you give more information? Feel free to close this if it is not actually a bug.
Denoise is a complex feature meant for use in production files, you can't judge the results on a monkey head. The bug report is about the Albedo pass being incorrect, which clearly shows. Not about demonstrating it's effects on denoising. However I can provide an example of incorrect denoising extracted from a real scene.
Original (Noisy)
Denoised with Denoising Albedo (Incorrect result)
Denoised only with Subsurface Color pass (Correct result)
What is happening is that the correct albedo is already present in the Subsurface Color pass shown below
The Gloss color pass however gives a white result
When the 2 are added together in the Denoising Albedo pass the resulting pass is washed out hence being incorrect and useless for denoising
Blend file can be found here
Denoise_Albedo.blend
Press F12 and wait for the render to finish.
Added subscriber: @adrenaline_hunter
I confirm the bug in real production
here an example scene: the albedo pass is causing a blurry denoise, while the DiffCol pass, wich in this case at least in teapot area seems better, does not retain all the infos (like Gloss, obviously).
non denoised scene
albedo denoise
diffuse denoise
albedo output
DiffCol output
full Blender scene
Cycles.blend
Added subscriber: @Rickyx
Added subscriber: @JulianPerez
I can confirm that too, for scenes where there are textures with small details the denoising albedo pass can't keep the texture detail. I've been combining all the color passes to have a clear albedo, but if there are textured glass or metal materials it gets trickier to fix with the color passes.
Look at this example, rendered at 64 samples only (the glass and fabric underneath would need a lot more samples to have a clean denoise), but look at the difference in the some of the fruits, especially the grapes, the denoising albedo looks weird and it doesn't seem to have enough color/texture information, so the denoise result looks more like an "artistic filter".
Noisy Image
Denoising Albedo
Mixed Albedo
Denoising Albedo Output
Mixed Albedo Output
Added subscriber: @sb_render
I have the same problem. See that in the render with cycles there are more details, and with the intel denoise we lost the light
Added subscriber: @LukasStockner
Added subscriber: @moisessalvador
I can confirm as well, I went through the original Intel documentation and was surprised at how good results they have on their page, and the claim that Denoising Albedo is the best input for the denoiser to have. The current denoiser albedo pass is simply adding the Glossy Color pass to all the others Color passes, but the Glossy Color pass doesn't contain percentage of reflectivity for things with frenel. The intel documentation doesn't specify a correct solution though, it's up to you what passes you choose and what combination, for example, if you want to add reflections to the mix or not, and how to do it, taking just the color or the actual first bounce. My current setup is to add Diffuse Color, SSS color and Translucent color, leaving Glossy color out.
So you solved the problem? I saw many tutorial that duplicate e apply the node denoiser at every path. But I think that is not comfortable do that.
This is not a bug.
The Albedo channel was designed for the original Cycles denoiser, which is completely invariant to constant shifts in feature passes. As you all noted, the Albedo pass works just fine with the original Denoiser.
Apparently the same is not true for OpenImageDenoise. In this case, we should adapt the pass to work better with it, but this is a feature request, not a bug - the channel does exactly what it was supposed to do, provide an albedo input that works fine with the original denoiser.
OK, but how can we solve the problem? How can we adapt the albedo?
In the next few days I try to setup a basic scene that works with Cycles and LuxCore so we can compare the albedos of the two engines, afaik OIDN in LuxCore can retain the details of the textures very well.
Even if OIDN in Cycles is a great improvement at this stage is quite limited, it's a pity to left a major feature like this with these limitations.
@LukasStockner It looks to me like this is a thing specific to the principled BSDF, which if I'm not mistaken was added after your denoiser? A quick look in the debugger tells me that for most settings, the principled BSDF adds the white specular component to the albedo when it might be beneficial to only use the diffuse albedo.
If I understand correctly now OIDN accepts an input that no node can generate?
For this denoiser to give the best results the albedo pass would have to combine Diffuse + SSS and Translucent passes, and I'm not sure if specular should be used too. Diffuse alone won't be enough.
Right, thanks for the hint, I found what's going on. D6289 should make the albedo pass more OIDN-friendly.
Added subscriber: @MaciejJutrzenka
Removed subscriber: @MaciejJutrzenka
As lukas said fixed in https://developer.blender.org/D6289 apperantly i think i am closeing this as resolved.
Changed status from 'Resolved' to: 'Open'
We only close bugs when the fix is committed.
ah didn't know. good to know also gives me idea for another status to add in proposal!
the bug will be fixed in 2.82? Any chance to test it earlier? Thanks!
Should be in the next daily builds.
ok, thanks!
