Default keyboard shortcut for Loop Cut and Slide causes a major problem with viewport control on Mac
Open, Needs Triage by DeveloperPublic
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 570X OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Loop Cut and Slide short cut (command R) causes an error - loops do not appear and middle mouse press forces the screen into orthographic views before stopping altogether. Also the scroll wheel starts to control the timeline scrub back and forth.
As above --
  1. go into edit mode
  2. use keyboard for command + R (will not produce expected loop result)
  3. then try and orbit around the object using middle mouse and you will be forced into orthographic views only perspective view won't work.
  4. In addition if you scroll the mouse wheel, it will move the scrubby slider on the timeline instead.
I only just downloaded this tonight... so it must be the most recent version.
Thanks
Doug
A bit more information: This may be caused by a conflict with Wacom drivers. I was in texture paint mode when this started (using the wacom tablet as a starting point).
