Not just opening
Closed, InvalidPublic
Operating system: window 8
Graphics card: Intel(R) PENTIUM(R)
64 BIT BASED PROCESSOR
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
IT OPENS AND THAN CLOSES
I HAVE INSTALLED 64 BIT BLENDER 2.8 VERSION IT ALWAYS OPENS AND IN 2 SEC CLOSES.
BUT WHEN I INSTALLED 32 BIT VERSION IT WORKED CORRECTLY BUT WHEN I OPEN NEW FILE TO MAKE 2D ANIMATION IT INSTANTLY CLOSES NO MESSAGE IS THERE OR WHEN I CLICK ON RENDERING TAB OR SHADING TAB AND ON MANY THINGS IT CLOSES INSTANTLY.
I TRIED TO RE INSTALL IT AGAIN AND AGAIN DOWNLOAD ZIP FILE BUT SAME THING HAPPEN
tom k (tomjk) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Sep 15 2019, 2:39 PM
tom k (tomjk) added a subscriber: tom k (tomjk).
When you say it opens and in 2 seconds closes, do you see the splash screen, a blank window, nothing at all?
When you open the 32-bit version, are you able to do things normally in the viewport until you change viewport render mode?
I suspect the problem is with your graphics card but you have not given a specific enough description of it. Please look here and consider attaching a system-info.txt.
Also please don't YELL, we can hear you just fine!
