Adaptive displacement off-screen culling/dicing and camera shift.
Closed, ResolvedPublicBUG
Operating system: Suse Linux 15.0
Graphics card: NVidia GTX 560ti (official drivers)
Broken: 2.81 e2df789c4800
Adjusting the camera's Shift X/Y values gives unexpected off-screen culling results and high memory use.
note: a separate camera (Camera.001) is used to control the dicing as it better shows the issue, but the same applies with a single camera setup.
  • Open adaptive_displacement_camera_shift.blend
  • Render and note that the dicing is centred on the plane as expected
  • If Camera.001 is moved along X direction, the culling position changes as expected
  • But if the Camera.001 Shift X value is set to 0.800 - instead of the subdivided area shifting to the right, it expands out along the X axis. Ram usage is also high.
Examples:
  1. Camera.001 in original position (peak memory: 69.19M):
  1. Camera.001 moved along X axis to 4m units (peak memory: 36.03M):
  1. Camera.001 in original position but camera Shift X value set to 0.800 (peak memory: 137.00M):
Expected result for 3. would be for similar culling and memory usage as 2.
So it isn't currently possible to split a large render into smaller sections as a way to reduce RAM/VRAM usage, then stitch externally.
@Mai Lavelle (maiself), I'm not sure if this involves adaptive render subdvision, but can you take a look?
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jan 9 2020, 3:33 PM
Did some digging, but spending too much time here.
This seems to be somewhat reversed, so Shift X is being used, it expands as @Paul R (intracube) , to add: if it is negative it shrinks...
I see it being used in QuadDice::eval_projected (rastertoworld takes shift X into account eventually), but not sure if this has to do with it
transform_perspective(&params.camera->rastertoworld, P);
Will confirm for now and have a look again later...
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".Jan 15 2020, 4:42 PM
Thanks for taking a look.
Similarly to the above; positive Shift Y values grow the subdivision region, negative areas shrink it.
A related issue;
Changing Output->Dimensions->Aspect also gives unexpected results. Setting Y to positive values causes the region to grow on both dimensions, but the expected result would be to only expand on the X dimension:
