Face orientation not showing flipped normals #69959
6 Participants
Reference: blender/blender#69959
Operating system: Windows 10
Graphics card: gtx 1060 3gb
Broken: example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screenShort description of error
After mirroring meshes via 'searchbar -> mirror -> Z' the Face orientation in Viewport Overlays showing that all faces are not flipped (blue) but after exporting to .fbx and importing that file to Unreal Engine or Substance Painter the normals are flipped.
Barrel_LP.blend
Barrel_LP2.fbx
Added subscriber: @TheBaja
Added subscriber: @tomjk
Face Orientation overlay works on the object's mesh. Your mesh's normals are oriented correctly and the overlay reflects this; however, mirroring your object on an axis will multiply its scale by -1 on that axis. When you export to .fbx and import to your other program, this transformation is being collapsed/applied.
You can see this inside Blender:
So the question is, should the Face Orientation overlay reflect the mesh normals or the object (transformed) normals?
Probably a discussion best suited for the devtalk forum, particularly user feedback . However I won't close this because I'm not sure if this*is// intended behaviour or not.
Added subscriber: @Jeroen-Bakker
This is intended behavior for the face orientation overlay. The reason for this is that otherwise the shading will be effected in the display. Cycles, EEVEE and workbench renders them correctly.
So question is that it is a limitation of the FBX exporter or that this also happens in other exporters.
@tomjk Can you prepare a file that shows what you describe?
I checked this yesterday, and the mirror modifier not only scales by -1 along one axis, but also inverts the normals.
Here you can see that the vertex order is different from what you would get when just scaling with -1.
I just don't quite understand why the .fbx exporter is exporting something else. When I import your provided .fbx file, the normals seem to be correct.
This is with mirror operation (Search -> "Mirror" -> Transform: Mirror, or Ctrl-M) as in @TheBaja's post, not the mirror modifier.
Maybe this helps to understand:
BarrelTest.mp4
Added subscriber: @ideasman42
Blender detects negative matrices which cause flipping and compensates for it to make negative scaled objects usable, not all engines do this.
Closing.
Added subscriber: @Rawalanche
Yes, I agree here. Correcting normals for negative scale is great, because it allows you to make more unique variations of assets with instancing by just mirroring them, and still get usable normals required for example for normals maps or refraction. When you have any asset which you plan to use with substance painter, or anywhere else really, just make sure to apply transforms first before exporting. That's always the best practice.
So when you know your asset has been mirrored, then:
