Bump does not work using a UVMap node as input #69971
Closed
opened 2019-09-17 09:07:31 +02:00 by Mikhail Rodionov · 12 comments
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.30
Broken: version: 2.81 (sub 11), branch: master, commit date: 2019-09-16 21:02, hash: 76650402f3
when trying to use bump maps - there is no result, both when using the bump shader node and when using normal mapping
create any object, (plane/cube or any other), apply Principled BSDF, add bump node, add amy image of procedural map, connect image RGB to bump height, connect bump normal to principled normal - no result
**System Information** Operating system: Windows-10-10.0.18362 64 Bits Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.30 **Blender Version** Broken: version: 2.81 (sub 11), branch: master, commit date: 2019-09-16 21:02, hash: `76650402f3` Worked: (optional) **Short description of error** when trying to use bump maps - there is no result, both when using the bump shader node and when using normal mapping **Exact steps for others to reproduce the error** create any object, (plane/cube or any other), apply Principled BSDF, add bump node, add amy image of procedural map, connect image RGB to bump height, connect bump normal to principled normal - no result [Based on the default startup or an attached .blend file (as simple as possible)]
Added subscriber: @M_Rodionov
#70001 was marked as duplicate of this issue
Added subscriber: @tomjk
To be sure, this is in the viewport? And you are switching to material preview or rendered mode? (Material 'effects' do not appear in solid mode.)
Added subscriber: @brecht
We require a simple .blend file to reproduce the issue.
Both, material/rendered & f12 all about EEVEE.
Added subscriber: @sebastian_k
I can confirm that, though only when using a custom UV input.
Try this file: bump_customUV.blend
If you connect Texture Corrdinates with UV to the Noise Texture it works, with the UV Map node it doesn't.
Tried with 2.81 (sub 11), branch: master, commit date: 2019-09-17 09:24, hash: 271c6794d6
I can confirm that, though only when using a custom UV input. Try this file: [bump_customUV.blend](https://archive.blender.org/developer/F7752950/bump_customUV.blend) If you connect Texture Corrdinates with UV to the Noise Texture it works, with the UV Map node it doesn't. Tried with 2.81 (sub 11), branch: master, commit date: 2019-09-17 09:24, hash: `271c6794d6`
Clément Foucault was assigned by Brecht Van Lommel 2019-09-17 13:30:21 +02:00
Philipp Oeser changed title from Bump does not work to Bump does not work using a UVMap node as input 2019-09-18 10:55:28 +02:00
Member
Added subscriber: @cheteron
This issue was referenced by f4f190a399
This issue was referenced by f4f190a399fb1bb17d5d80f5f8951a655ca519c6
7 Participants
Reference: blender/blender#69971
